i think i have everything for my 240sx sr20det am i leaving anything out????????
bman2033
hi guys, i have a 1995 240sx and right now i have the s15 turbo, fmic, koyo radiator, greddy rs bov. I have megan racing exhaust mani and down pipe ( i donot know if i should upgrade those or not) but everything else is stock sr20det parts in the engine. I am getting the wiring specialist to make me a new harness from scratch cause i dont know if the guy before messed up or what but it looks ugly wiring job. i also have deachwerks 740cc injectors for when i tune the ecu for the s15 turbo im trying to go about 15psi and i figured that would be good enough, although i see many using the 555cc and i dont know if i made a mistake getting the bigger ones. ijust got my stock ecu from ebay for 180 shipped and i will send that one out to either JWT or Enathlopy for the final tune chip. i will be purchasing the tomei exhaust mani and a oil catch can (are those necessary). and i think i might get the greddy intake mani too but im not to sure. and lastly i want to get a upgraded coil pack but i cant find any but the split fire, is that the only upgrade brand??and is that neccessary?? so guys tell me am i missing anything that would be a good purchase to make before i throw it all together?? please nothing out rageous but anything u all can suggest please and thanks.
bman2033
bump
spider_slayer
Car: S14 240SX
S13 240SX
i'm tempted to recommend a maf jsut so you have room to grow, but since your jsut using a t28 its not absolutely necessiary.
also, if you get the 555's you can save some money there and then save some more money by just using a safc to tune with.
jsut my .02
bman2033
u know i completely forgot to metion that i have a z32 maf too already not installed.
brandonlgilbert
Car: 1996 240sx SE w/ S14 SR20DET
I would suggest a little bit of preventative maintenance on the motor. Such as, water pump, front and rear main seals, new belts and hoses, valve cover gasket, and oil pump.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
^ don't want to spend all that $$ on nice things and have your motor overheating and spewing oil everywhere. I vote for a new thermostat and new spark plugs too. You'll also need a full exhaust (I'm sure you've thought of that and just didn't write it though)
