i think i have a short
muscleinc1320
Car: 1991 nissan 240sx along with many others
well its more like i know i have a short just dont know where to start looking. rebuilt this ka24de motor sounds fine and runs good but the battery keeps draining after leaving the car parked for a couple days. checked all the fuses and everything is good. it so odd too cuz if the battery is a little low and you have the key in the ON position the Neutral Safety Switch buzzes. i know that this is kinda a hard question to answer but does anyone have any idea as to where to start looking for this short? or why that switch makes a buzzing noise?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Don't over complicate things. Test your battery terminals for corrosion and tightness. Check your batteries cold cranking amps. And check voltage while its running. A local autozone or whatever will test you battery and charging system for free.
muscleinc1320
lol i work at autozone. brand new battery and cables so all those are good
locoluna825
Car: 90 240sx coupe
wish i worked at autozone
muscleinc1320
it aint that great. the only benefit is the discount i get at work and the hook ups at shops we do business with
