Jeff Williams wrote:Do you actually dismount the tire?, or do you rotate the directional tread, so it is actually the wrong direction, ro do you just swap the fronts to the back and the backs to the front?
I dismount flipping side to side, rotating front to back, keeping all tires rotating in the original direction only. I am repeatedly told by every tire expert this is no longer necessary.
My only complaint is my AVS db aren't wearing fast enough, nor are they feathering in the least. These are not S2, either. Looks like I'll be stuck with them another 7K - 10K miles when the tread will (hopefully) be half used at 24K - 27K.__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
