I think I fried my Power FC. F#CK
Reignman
Car: 1995 240SX
I was wiring my electric fans through a temp switch and a relay and as soon as the temp switch kicked on the car shut off. Now the car wont start and the fuel pump wont even prime. When I try to connect to the Power FC on the laptop I get a connection error. I opened up the Power FC and I cant smell any burning or find any signs of it. Does anyone have an idea if it could be anything else? Is there an ECU fuse that could have blown? I really hope thats it otherwise Im f#ucked
Carl H
proly fried the ecu fuse...check the fusebox for blown fuses and fusable links...worst case scenario i can take a look at it and see if its really dead...
Reignman
Car: 1995 240SX
Thank goodness, it was a blown fuse. I was just about to freak as this was the last thing I needed to do before I was ready to tune and drive. I will have to figure what I did wrong on the fan wiring to the relay. I will also be adding an inline fuse this time.
Carl H
if i were you man use the stock fan wiring for the ac fan.thats how i have my cooling fans rigged up, hks fan controler runs one fan automaticly and the other fan is on the other relay hooked up to a swtich for manual control.
