Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Wed Jun 08, 2005 12:33 am
02 doesn't affect WOT.
Temp Gauge (if stock) is worthless, you can gain 20 degs. of coolant temp and the ECU will cut out a few degrees of timing, but the gauge won't budge.
Basically I would look to increase flow through your radiator, you can do this with a nice $15 trip to Home Depot.
More importantly I would address your coolant. Replace the coolant you have now with a 70/30 mix (more water than coolant).
The Nismo thermo will just delay how long it takes for the motor to begin to warm up.
Those simple chores should lower cruising temps a solid 5-10 degrees.
Make sure you bleed the system of airbubbles when you open the coolant system.
