thank you ill look for that.spoolings14 wrote:your local home depo or sears has a socket made for stripped nuts and bolts. it worked great.
what are you saying?ZiG wrote:vice grips? cutter?
If your thinking of the gator grip i have broken way to many of them to even give it a try.spoolings14 wrote:dats the same exact thing dat happened to a buddy of mine, your local home depo or sears has a socket made for stripped nuts and bolts, jus ask for sockets for stripped nuts and bolts they should kno wat your talkin about. it worked great.
the hack saw isnt a bad move either but it worries me that the tip wobbles like mad as it cuts. but...destroyyourmind wrote:break out the hack saw or plasma cutter
That makes sense actually. thank you, I dont know if its worth It, I've got to ask around, because mostly I want a civil daily driver. and weekend auto crosser.MA JasonG wrote:The engine torque dampener and engine mounts might actually give you more vibration throughout the car.
yeah that sounds like the plan. It can be done.nxpoweredsr20 wrote:we heated it up with a little propane tourch and after a bit of tourquin on it with the impact it came off
The tool from home depot worked, thanks it wasnt the same one as yours i think, but damn it was effectivenxpoweredsr20 wrote:ya i had that problem on my buddies 89...craftsmen makes a bolt out kit...
