I still haven't got the answer i need LOL
J30_Kidd
Car: 95 J30 Pearl White
Ok one simple Question, :confused: Where in the world is this Speed Sensor Buffer located in the 1995 J30. I took apart a gauge assembly at the j/yard and didn't see it built into it. I've swapped the VSS it self so many times with the code 14 coming back up. :wtf2:
I just need to know where it is located and possibly how to get to it. :facepalm:
That is all, Thank you!
HELP!!!!!!!!!!!!!!!
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
It is somewhere in the transmission
J30_Kidd
I know where the VSS is
But the actual buffer, from what i have read i'm to imagine that there is a device between the VSS and the ECU that converts a signal.
Am i wrong on this?
J30_Kidd
Just called Infiniti in Austin and they told me a VSS code is not the speed sensor but the rev sensor on the other side of the transmission, LOL Now i know what to go looking for! maybe even the turbine sensor
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
Try this to test all the trannies sensors
Transmission Self Diagnostics
using AT light below your temperature gauge on the dash
1-Warm up engine
2- Shut off car and turn ignition switch to ACC position
3-Wait 5 seconds
4-Move shifter to D
5-Turn ignition switch on do not start
AT check light should come on for about 2 seconds
6-Move shifter to 3
7- step on gas fully and release
8-Move shifter to 2
9-Move shifter to 1
10-step on gas fully and release
The At Check light should start flashing 11 flashes a
slight pause and start over again. All flashes should
be the same length, any flash that is longer indicates a
trouble the following list is what the trouble circuit or part is.
A longer flash indicates
1st Flash Revolution sensor
2nd flash Speed sensor
3rd flash Throttle position sensor
4th Shift solenoid valve a
5th Shift solenoid valve b
6th overrun clutch solenoid
7th tourqe converter clutch solenoid
8th fluid temp sensor
9th engine speed signal
10th turbine revolution sensor
11th pressure solenoid valve
yodawill2000
Car: 94 Infiniti J30
I might add that mine does have 1 long flash before the 11 short flashes.
J30_Kidd
You know, i have done that in the past and no codes popped up on me unless there was a problem with everyone lol, naw but seriously none of them had a longer flash to my knowledge. I'll try again but last time round i did this i had these problems already and no long flash on any. I just wanna get this engine light taking care of already.
