180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Feb 03, 2005 9:57 am
Another place to check are the rubber fuel lines in the engine bay and at the fuel tank. I had a small leak at the one above the intake manifold and another larger leak at the large rubber line that vents the air in the fuel tank to the filler. If you haven't done so already, switch the rubber fuel lines with new (injection, not low pressure) lines.
