So about a month ago I had my alternator belt break on me unfortunately but I made it about 2 blocks from work before my battery gave out, so since I was replacing that I decided to replace all the belt besides the once that's way behind everything that I couldn't really see until I had all the belts off.
Back to the point so about a week ago I was under the hood and I noticed the ac belt was not where it should be. I then jacked it up to take a better look and I noticed that the tensioner for the ac belt was completely gone except for the bolt. Long story a little shorter I cant find where to get an oem one anywhere nor can I find a picture of one to see how they have it set up because their not setup like the other tensioners. Basically I'm missing the wheel and the bolt so if someone could be o so very kind and snap a couple of good pictures of their ac belt system that would be great! Ill probably have to go to a junk yard and see if I can find something similar. Next time I'll loctite it...
-1997 q45 (97-01 should all be the same maybe even past 01)
- Just need a couple of good pictures of the ac belt system tensioner is key
Thank you in advance Ive been searching everywhere and I've came up with nothing...
