I got a low mileage gt35r for $650, I got almost new 630cc deka injectors for $200 (even cleaning would only add $150), brand new dxdracing clutch $380, and reground my flywheel for $40... I have no idea why you're stuck on mercedes injectors or a "new" turbonetics turbo
I don't know where you're looking, but all the wrong places for sure...
Let me make a recommended list for you staying with the vg, and one for the rb... I'll round up
VG:
clutch $400
injectors $300
fuel rails + fpr + hoses $300-500
holset hx35/40 sized turbo $250-400 (or rebuild factory T3 to a stage3 60-1 for $260)
custom downpipe + exhaust $500-800
nistune $450-550
reground cams $200
upgraded cam springs $150
turbo swap parts, manifold, crossmember $50-200
gutted intake manifold $400
gaskets $50-100
RB:
rb25det + trans + ecu + harness $1600-2100
clutch $400
injectors + clips/adapters $400
gt28-gt30 sized turbo, probably precision $500-700
no one will recommend nistune, but for comparison $450-550
aftermarket cams $300-600
aftermarket exhaust manifold $300-1500
aftermarket intake manifold $300-500
custom motor mounts $250
custom trans mount $150
custom driveshaft $300-400
aftermarket gauges (or cluster swap) $300-500
custom wiring $????
gaskets $200-300
And there's some other stuff you'll find along the way, little things, clips, connectors, the fact that nothing can be picked up at a parts store just like that...
