float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Dec 22, 2005 12:56 pm
IF you can keep you KA-T project in one peice, it can be a great motor. I've seen/heard of a lot of shelled KA-T motors though. I think the problem with a budget KA-T is that you are at the limits of the motor internally, whereas w/a stock CA, you're nowhere near the limits internally, and can make the same power with a minor SR T25 turbo upgrade.
Ofcourse the flip side to that is IF you get a good condition CA motorset. In my particular case I DIDN'T. Bad rings, with possible damage to the #3 cylnder (I'm not sure if it was from the one overboost (hit boost cut on stock turbo) or if it was just like that when I bought it. )If you've got to overhaul the CA, it's still prob cheaper as a gasket set, rings, bearings, water & oil pumps, and timing belt, is still less than the required forged pistons and rods needed for a reliable, high HP KA-T.
