I searched.....SR20DET starter - Alternative to JDM?
SpeeDDrifT
Car: drive. drift. drive....um drift...SAFELY. k
Need a new starter for a redtop SR20DET and a few questions...
Will the Sentra SE-R starter work?
Is the 13, 14, and 15 starters the same?
Does anyone have a parts list with parts numbers for a starter rebuild?
Thanks in Advance!
mrzabala
Car: 93 Nissan 240SX SE Hatch
The only usdm parts that will work for an sr starter is the solenoid from a KA. Other than that you will need the head from an SR as its the only starter to fit on through the transmission and engine block of an SR. I have a starter for sale. Its been checked and its working great (I had to do the test as the employees were noobs). Buying a KA starter will get you about $40-60 and you can't use the head, so buying mine will help you in not only having a solenoid, but the head. Heres the link:http://cgi.ebay.com/ebaymotors...ZWDVW
ILikeMy240sx
Car: SR Power
I have a starter for sale if you want.
please email me at [email protected]
mrzabala
Sup Taesoo. Hey, if you want that starter sold, try ebay. Sold mine in 2 hours at buy it now price. Oh and can you check my thread? zerothread/268215
SpeeDDrifT
waiting on your response........sent email. Anyone else selling a starter?
Sil80sushi
Car: 90 240sx
dang i was hoping there would be a USDM starter that would work with the SR Mine is going out how much do they go for 40-200? (Used-New)
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
A new starter is 600+ so just go with used. http://www.sr20store.com/ Always has known good used parts. I have used them and recommend them.
mrzabala
Whats wrong with ur starter. IF your gear isnt popping out than its an easy fix. A ka24de solenoid matches.
Sil80sushi
Car: 90 240sx
God damn 600 Bucks woooowwww thats crazy but thanks for the info Doridori and Mrzabala
SpeeDDrifT
I am buying Taesoo's starter. Autozone wants $60 for a solenoid switch.
slowasss13
Car: s13 sr20det tomai o2 housing blits down pipe hks pro power exhust greddy v spec inercooler 6 puck s
dont no if this is true but i think i read on hear if u take a sohc ka starter and put the front part of the sr starter on it it will bolt up and work .not sure thought. .....600 buck for a starter is steep you can always go to a eletcrik moter rebuild place and they can rebuild it for u
SR Superstar
Car: 91 SR
I came across this thread in a google search... Mishimoto just released an SR20 starter which is way cheaper than an OE replacement and it has a lifetime warranty, check it out on their website.
90_240sxx
Car: 1990 240sx
here you go i just finished rebuilding mine and it work great. zer...arter
James@CI
Car: 89 Nissan 240sx with SR20DET
Hey here is that Mishimoto starter brand new lifetime warrenty 200 shipped.
http://www.cimotorsports.net/p...age=1
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Enjuku sells new ones also.
http://www.enjukuracing.com/is....html
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
CA20E starter from a 84-88 Nissan 200SX will work, if you cut one of the ears off and don't mind bolting it in with one bolt.
It's a bit bigger than a real SR starter, so you have to remove the intake support that goes around the starter.
I've been using the old CA starter on my SR since I swapped engines, the bolt has never loosened up once. Still starts with out a single problem, and it's the original 22 year old starter!
scherger_16
Car: 1990 240sx SR20DET, 1993 Nissan D21 pickup
Second Shadow
Car: 93' 240sx, s13 blacktop sr20det
I have an s13 blacktop, I used a KA24DE starter. I had to change pulleys as the SR belts have an extra rib on them, and I had to put a spacer on it to keep from binding on the starter housing. this wasn't a big deal though, the auto parts store had extra spacers in a parts bin and used an impact gun right there to change them out.
Other than that, on the front of the starter part of the housing will hit something when you try to bolt it up(I can't remember what it was now). I used a grinder and took about 1/3 of an inch off of it. It looks like on of the posts that the grounding wire is supposed to connect to.
anyway, once that part is trimmed down it fits fine. been driving on mine for about a year, costed ~$120 I think? IDK it was a while ago. Hope this helps.
daquickness30
Car: 240sx Hatch with a stock SR swap
Second Shadow wrote:I have an s13 blacktop, I used a KA24DE starter. I had to change pulleys as the SR belts have an extra rib on them, and I had to put a spacer on it to keep from binding on the starter housing. this wasn't a big deal though, the auto parts store had extra spacers in a parts bin and used an impact gun right there to change them out.
sounds like an alternator
