I searched but everything I found contradicted the other. HUD cluster sohc
destroyyourmind
Car: 89 240sx hatch ka24de. 91 240sx hatch.
will a sohc digital HUD work in a DOHC car the cluster is from a sohc coupe and I have a 91 hatch. it seems everywhere I look someone says they switched out the tach and it worked and others say it doesnt work? and if it doesnt work what is needed to make it. -thanks
destroyyourmind
if it works on a sr20 it should work for dohc right?
modulation
This I know for sure.A DOHC tach won't work in a SOHC, and a SOHC tach won't work in a DOHC.The tach-signals are different.I did take a SOHC tach and put it in my DOHC car and it doesn't work.
I do think the speedometer will work. I'm 99% sure it will but I'm not sure..
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
The sohc tach will not work with a dohc motor. However you can swap the sohc tach out for a dohc tach. Everything else will work fine.
destroyyourmind
so the speedo and everything will work, and do you know if the harness is the same
modulation
Yeah the harnesses are the same.
But harness for Analog Cluster is different then harness for digital HUD.
