i searched a code 41 but found no answer.
donnie89240sx
Car: 1989 nissan 240sx coupe
ok i have a 1989 240sx with the ka24e it told me a code 41 so i changed the intake air temp sensor and still there how can i get it to sop giving me that code? its making my car run bad and it wont idle worth a didly. any help would be greatly appreciated.
donnie89240sx
ok can anyone help me at all? nomatter how i clear it. it keeps coming back. well i would appreciate any help.
Rex
Car: None
donnie89240sx wrote:ok i have a 1989 240sx with the ka24e it told me a code 41 so i changed the intake air temp sensor and still there how can i get it to sop giving me that code? its making my car run bad and it wont idle worth a didly. any help would be greatly appreciated.
Here's some info regarding ECU's and codeshttp://www.nicoclub.com/articles.php?id=60332
Did you disconnect your battery overnight after resolving the faulty item?Are you sure you resolved the "fault"?
DALAZ_68
Car: 90' 240sx CA18det
arnt those the OBDII codes....
or are they all the same
Rex
Car: None
The 1st section of codes (2 digit) are listed as Pre-OBDII codes.
DALAZ_68
ohh mah bad
lesson of the day....dont just glimps ****...take a second to read it lol
donnie89240sx
i know how to pull and clear them but everytime i clear it then start and drive the car then pull codes again and its back. i put a new ait sensor. a couple of parts houses kept calling me a liar when i said my car had one.i need to find out how to get it to stop giving that code.
albert_ey
Car: 2007 Nissan 350Z
I got this off a program I have, try all of the following.
donnie89240sx
ok on that note which wire do i check on the ecu harness? theres alot of wires hahaha
albert_ey
I'm going to e-mail you the image so that you can zoom in and read it better.
donnie89240sx
when i put a tester on the ait sensor wires it was showing 4.2v and when i checked the sensor with the one that checks for closed circuit but when you put them together they beep and it showed 0.1 is that what is supposed to be or what? my chts i know was sending like 5.2 and when i checked the chts it showed 528 with that one that checks the closed circuit while the motor was running....... does this make any sense. im going to go look at that pic now my aol mail has been acting up on me.
