i screwed sumthin up!
sil820
i need 2 replace my valve cover gaskets so i did.. i left the car at my friends house and he decided to help on it while i left 2 work he cleaned out my TB and he installed the gaskets and he installed a new 02 sensor that i had... the problem is my car is idling super high n running like crap..it use 2 idle at 800-900 now its idlin at 1800-1950. what do u guys think could have done that? im gonna switch the o2 sensor out 2morr back 2 the old one and hopefully it will be back down.. u guys have any idea what it could b if its not the o2 sensor? thanks for your help
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
JUST RE-IDLE/TIME THE ENGINE..... THE OLD SENSOR MAY HAVE BEEN FAULTY AND THE NEW CLEARED THAT UP SO YOU NEED TO RESET TIMING AND IDLE.
Wulfgang
He cleaned out the TB? Could he have left a vacuum line open? That would make it idle high. I seriously doubt an O2 sensor could throw the idle off by that much, if at all.
wga240
Car: 90 Hatch w/ RB20
Definitely sounds like a vacuum leak, as Wulfgang suggested.
sil820
thats wut i thought it's sumthing leaking..ill recheck everything in an hour..but forsure its not the o2 sensor??? should i reset the ecu? how do i re-idle the engine? mess with the timming? cuzi did that and it was still the same..
Joe
yes its a vacuum leak, the o2 sensor dosent affect idle when its running open loop.
sil820
could it be the tb gasket at all? b/c mine cracked apart so he bought tb gasket paper thing and made a double of it..
wga240
If air is leaking out of the TB to intake manifold gasket then yes that could be it. Do you have a boost/vacuum gauge? If so it should be reading somewhere between 19-20 in mg of vacuum at idle if you have no leaks. If you don't have a boost gauge, it's a fairly cheap and worthwhile investment for detecting vacuum leaks and making sure you're not overboosting ;)
sil820
i found it..its the TB sensor..it just had 2 be turned a little...tripped me out man.. i took everything off and put a new gasket.. and it still had the problem..then i noticed u can move the tb sensor so i did and it worked! the werid thing is that after switching the o2 sensor it idles about 100-200 higher and runs slower.... so im gonna switch it back 2day when i getta chance ...and hopefully it will b back up 2 speed again..
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
The TPS? Sounds like you need to adjust it. break out the volt meter or use the SAFC2 so you can monitor it when you adjust it.
sil820
ya tps i 4got the name for it..i used my rev/speed meter and just watched my idle and set it as far as i could w/ low rpm.
Yellow4g63
dose the rev spped show tps voltage? if it dose find out what it's suppose to be at and set it to that voltage.
sil820
any 1 kno what the tps voltage should be?? my rev/spd meter only shows battery voltage. after redoing everything my car feels like its running a lil slower.. it idles at 1000 now instead of 800-900.. any clue what it could be?
