i replaced the turbo inlet gasket and everthing is cool but the psi is not?????
bman2033
jst like it says i replace the gasket and i bolted those things on tight and no leaks thenk god (knock wood) any how before the leak i remember the boost gauge reading about 6-7 psi and know it goes up to 5 and no further than that. i am running stock boost or at least i should be on the stock t25 turbo, why is this happening or did i accidently turn the boost down without knowing, also how do you raise the boost or turn it down if you dont have boost controler or is it even possible or maybe leak somewhere else??? i will check tommorow to wrench those bolts on again to make shure there on there tight.
bman2033
bump
da40
Car: 1995 SE 240sx
check for vac leaks easiest thing u can do
Vr6WantSr20det
like he said check for vaccum leak, or its possible u messed up or accidentaly tampered with the waste-gate actuator. But definately check for some sort of boost/vaccum leak as thats an easier fix.
bman2033
how do you adjust the boost i tested and everything is sealed with no leaks, its weird it was at 7psi and know its at 5, i have no boost controller
