Rouge5 »
https://forums.nicoclub.com/rouge5-u266765.html
Fri Oct 20, 2017 1:10 pm
Hi MalcomY, my Altima had a clunky noise in the front suspension, and also sound with every little movement.
So I remove one tire and then put the jack below the control arm and start to lift all the assembly (with a piece of wood to prevent damage), like the car was in the ground with the tire, and then I checked all the bolts/nuts.
I discovered that the "connection rod" the piece that connect the strut with the stabilizer bar, was very loose and worn, so I changed it from both sides and problem solved.
It could be that, or just need to be greased
