I removed my hot air intake today...
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I was out buffing Lola this morning and decided to check my air filter. The car has been sitting for about 2 hours. When I removed the filter, the STILLEN bell intake was still hot to the touch, nearly 100 degrees!
The filter has about 1500 miles on it since I cleaned it last, but it has been so dry and dusty that it needed cleaning again.
I had the original filter box, and decided to swap it out for the summer. I am doing 90% in-town driving, and the hot air is not that good for performance.
Besides, I don't need all that extra intake noise, now that I have the magnaflow system on the car .
Now it is going to be a PITA to change the oil filter!
Q45tech
The reason one changes the oil filter from the botton [every 90 days] is to spend time examining things from the bottom that might be on the verge of failure or leaking................due to gravity very few things leak upward.
Check security of belly pan, etc.
66mgb
Car: 1992 Q45 Modified w/ NICO Goodness
I second that motion! FYI I looked up my Q's skirt the other day lo and behold, my steering rack boots were cracked and leaking.Looks like my baby is going to get a new rack soon.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
I say,
"If it hasn't fallen off the car, then it must be fine - no maintenance necessary."
That's my motto!
I guess, when I jack her up, remove the tires & wheels, polish the exhaust pipes, and detail the suspension, it is a good time to change the oil. I will be there anyway.
Modified by Jeff Williams at 12:33 PM 6/24/2006
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Hope you didn't remove the resonator behind the bumper!
Modified by maxnix at 9:31 AM 6/24/2006
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
66mgb wrote:I second that motion! FYI I looked up my Q's skirt the other day lo and behold, my steering rack boots were cracked and leaking.Looks like my baby is going to get a new rack soon.
No mechanical fluid exchange yet or what? Hos is its appearance? Maintenenance history?
The boots definitely need replacement, but perhaps not the rack.
66mgb
Changed PS fluid over to Valvoline Synthetic about 2 years ago.Hoses were leaking prior to that so I replaced those last year.When I had the chainguides done last month, I replaced the PS pump because it was getting noisy.Had car aligned on Thursday, so I checked out underneath while it was on the lift. Rack seals are shot as well as the boots. Leaking nice clear PS fluid about 2-3 oz overnight.
Didn't mean to hijack this post - Sorry Jeff
66mgb
I might add - I've contemplated installing a pop charger, but after all of the posts on underhood temps, I'm going to stay w/ stock for now. I kind of enjoy the stealthiness of the Q. Quiet power for now!I'm still going to uncork the exhaust w/ a 2.25" system in the near future.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
No, it is all back to stock. And MUCH quieter now inside. i may not change the exhaust resonators now. Iwill drive her a week or so, before I make my decision.
vicQ45
Car: 1979 Cadillac Eldog, 1987 Wagovan, 1968 Firebird 400
66mgb wrote:Changed PS fluid over to Valvoline Synthetic about 2 years ago.Hoses were leaking prior to that so I replaced those last year.When I had the chainguides done last month, I replaced the PS pump because it was getting noisy.Had car aligned on Thursday, so I checked out underneath while it was on the lift. Rack seals are shot as well as the boots. Leaking nice clear PS fluid about 2-3 oz overnight.
its been a while since i've had my nissans, but shouldn't you have ATF in there?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
wait a second jeff, did you take your new exhaust off??? what am I missing?
Rex
Car: None
Wes won't believe it, but I put the stock air box back on Da Beast today. Inititial impression is quiter in a "smooth" way. I'll take it out for some real threashing tonight and see if I can tell much difference .
I think I have 2, maybe 3 Stillen Pop Chargers for sale.
And there was 1 K&N drop in that needs cleaning/oiling (free to anyone that wants it).
66mgb
Not sure if it's mandatory - anyone care to comment on ATF vs Valvoline Synthetic PS fluid?
Q45tech
Remember ATF is just dyed RED for identification.
Assume that Nissan's statement of equivalence Dex111 means that any Dex111 can be substituted for PS. BUT not the converse in an AT.
You can adjust the actions of the PS system by adjusting the viscosity of the lubricant.................easy to find the viscosity vs temperature of all ATF at least up to 212F.....................measure the temp of PS.............both start out cold at the same temp but PS doesn't need to adjust lockup or shift pressure .............the steering force just changes a little and your arms/brain react and adjust.
Synthetic ATF has a possile higher sustained operating temperature and a more stable cold viscosity............look it up and compare vs Dex111.
Anyway oem racks and pumps last 300,000+ miles and 16+ years if you change the lubricant [frequently- annually] to remove the wear particles and acid from fluid breakdown.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
elwesso wrote:wait a second jeff, did you take your new exhaust off??? what am I missing?
No, I just put the OEM filter box and ducts back in the car. I got tired of the underhood noise cancelling out the nice rumble from the exhaust.
elwesso
2007 BMW M Coupe
were you thinking about changing the exhaust resonators? Exhaust too loud?
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
It is still a little too loud at 1,500 RPM. I will be contacting Magnaflow, to see if there is a better resonator or rear muffler for my application.
It is liveable, but I would prefer not to have the resonance.
Rex
Car: None
Jeff Williams wrote:No, I just put the OEM filter box and ducts back in the car. I got tired of the underhood noise cancelling out the nice rumble from the exhaust.
Mine is noticeably quieter as well, but oddly enough it seems to be idling slightly higher, have you noticed any idle RPM differences? (keeping in mind the inaccuracy of the tach, I'd still say it's a touch higher)
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
Mine was idling about 800 before I changed it back.
My remote quit working now . I wonder if that has anything to do with it.
Rex
Car: None
Jeff Williams wrote:Mine was idling about 800 before I changed it back.
Might be the batteries , the brain/LAN or the operator
TAI CHI MASTER
Car: 1991 Q45 PEARL WHITE
Okay, you guys are making my head spin I read an older forum where it was Mobil 1 or MMO that was good for Ps fluid. I changed my power-steering fluid after one of my relations put transmission conditioners in. At first the Ps worked better then before however, it then started to lock mid-range or neutral. I had it purged and I replace the regular powersteering fluid with MMO now, its back to normal.
Q45tech
Who would ever use MMO in a functioning power steering system. Now I could see a tiny bit of LUCAS stop leak in a road emergency until the components were replaced...............but MMO no thanks.
The FSM has a nice section on setting the proper pinion gear preload vs a measuring of the steering wheel required turning force [9 pounds?].
Been using ATF [conventional and synthetic] for about 15 years since the 12,000 mile entire every system [ATF, brake, AC oil, oil, coolant, dif fluid replacements in 1991.................same rack, same pump --not same hoses.
DrewQ45
Car: 1990 Infiniti Q45
Q45tech wrote:The reason one changes the oil filter from the botton [every 90 days] is to spend time examining things from the bottom that might be on the verge of failure or leaking................due to gravity very few things leak upward.
You still have to get under the car start the drain anyway so that's when I have my looksee.
