^^I am curious to see what you have done, especially regarding the catch can on your M. Although not very attractive they work.
Nothing wakes these cars with 60+k (very dependent on the individual vehicle) on it like a thorough top end cleaning.
Recently I have been recommending removing the entire plenum and cleaning it correctly. Instead of spraying something in one port or infront of the throttle to chemically remove any sludge or oil that gets into the intake tract under normal operation. However I don't like to push my luck with catalytic converters altering the AF ratio to the point that a throttle service typically does can cause a flooding condition and saturate the catalyst material that can cause long term damage.
msvara wrote:The Fuel system service cost $169 CAN and the TB idle adjustment cost $119.
The 1 hour labor to reset your Idle Air Volume and Self Learning is excessive IMHO. They charged you almost $300 for an induction service. :tisk
Although at any price having you (the owner) satisified is worth it. However I hate to see members get burned on things.
