OM3GA »
https://forums.nicoclub.com/om3ga-u39603.html
Sat Apr 10, 2010 2:19 pm
Next, i was trying to figure out what to do for my exhaust system stuff. Initially i had planned to buy a Tomei elbow and an HKS Downpipe. After figuring out the price of that i figured i would go with the PBM Max flex cobra which is the best design out there right now.
So here it was, took about 2-3 weeks for it to get to me but it was well worth the wait.
The first thing that happened to me when i starting taking parts off the engine was a bolt snapped inside the turbo housing while trying to remove the turbo elbow. This was one of the BIGGEST pains to get out ever, it was in really far which made it even more difficult. After about 3 days of trying to get it out, it finally came out, without any damage to the threads. After two days i thought i was going to have to drill it out and re-tap it a little bit larger. That did not happen which i was thankful for and decided to get all brand new studs and not use any bolts at all.
I gobbed them with anti-seize and they went in.
Next i was deciding on which catback to get, i was initially set on the megan 3" because i had a megan 2.5" and it was the best fitting thing in the world. Amazing ground clearance, you couldn't even see it if you looked at the frame rail from the side. I definitely did not want a catback with a full resonator because of the cars height.
Since the Megan 3" was the same as the Buddy Club Spec II that i was also looking at, i decided to go with the Buddy Club.
The PBM Cobra went on with a brand new outlet gasket as well as new locking nuts.
It fit very well and was pretty much parallel with the frame rail.
There was also plenty of steering rack clearance.
As well as Clearance next to the transmission.
I also bought a resonated test pipe to keep the noise down a little, First i bought the ISIS one because i thought it was resonated then it showed up in the mail and it was actually just hollow. So the Project Nissan one was ordered.
Next the catback went into place.
Pretty good fitment except for this slip fit design which i cannot stand. i may even sell this catback because of this design unless i get a V-band put in right there which may be a good idea. Anyways, i don't see how this could possibly seal.
This side is better, but i would want both sides to be like this.
Next up, i set the car on the ground. To my surprise i had way less ground clearance than i thought i would. (Keep in mind i'm not using the stock mount that goes from the transmission mount to the downpipe which is probably what is causing this droop.)
I didnt think it was too bad until i decided to measure it.
Since i have always been using a Peak Performance transmission mount, (which i love) I am going to have to do some research to find another mount that is just as good or better that has the studs for mounting the stock bracket up to it. I thought right off the bat, "I need to get a Nismo mount now" but the truth is, the nismo is way too soft for my taste. I did find another one made by a company called Avid but you have to drill out the holes in the cross member which i do not want to do unless i absolutely have to.
I was just about to order theirs when i did yet even more research and found one made by a company called Super Now. Which is the one i am going to go with. It is solid Aluminum so it is going to be a small upgrade from the Peak one which i am happy with, I would rather upgrade to something more aggressive then downgrade to something way softer.
Here is the mount which i just ordered
That way i will be able to utilize the stock bracket setup like this.
Pics borrowed from Positron.
Anyways i will hopefully be getting this sorted out soon, i am still waiting on arrival of a few other things as well as being extremely busy.
For now, Check out this Giraffe.
Modified by OM3GA at 5:26 PM 4/10/2010
