Oh i will... you just wait and youll like it.OM3GA wrote:Thank you, i hope you will take pictures and update your build thread this winter also.
Well you know that the clutch fan robs power vs. an E-fan? My sr made 7 more horse and 13 more tq....OM3GA wrote:
Thank you, i only like the best for my setups
Yeah i understand that 100% however it still is the most efficient and best cooling. If i was concerned about that amount of power i would just turn the boost up or change the turbo and set it all up for 300hp. A lot of pro high hp cars use the stock mechanical fan setup such as these two right here.Beanstalk wrote:
Thanks man!zach-Ka wrote:That cat is looking pretty intense. Everything seems to be coming along great man. Its gonna be very clean...
This one is sold, i can get you one for around $500 if you'd like.Hooked on 240 wrote:how much for the ka intake manifold? If you wanna sell it, email me @ the email in my profile.
Car looks good!
How do you figure a clutch fan cools better than an E-fan? Or is more efficient? Efficient is production without waste... In this case your robbing power to cool the same. I'm all about your set-up its sexy. I was just curious to your logic behind it?OM3GA wrote:
4Real Works D1 Toyota Soarer 600HP
Yasuyuki Kazama's D1 S15 Silvia 509HP
Thanks man!
Basically the CFM rating on the stock fan is a lot higher than most (yes most) electric fans. Sure the initial gain is there from the loss of weight being spun by the crank. When the fans kick on there is still drag caused by the alternator having to power the fans which most people dont put into account when they talk about their e-fan setup.Beanstalk wrote:How do you figure a clutch fan cools better than an E-fan? Or is more efficient? Efficient is production without waste... In this case your robbing power to cool the same. I'm all about your set-up its sexy. I was just curious to your logic behind it?
Thanks man, the key is to take your time. From start to this point has been about 11 months. I have not had a ton of time to work on it especially lately, but patience is definitey key. My goal was to do the swap as clean as possible. As well as use high quality parts and make it how I want it to be which is not extremely high hp its clean and reliable.J14cm7 wrote:what a clean engine...teach me your ways david
Thanks man i have been a fan of your CA setup for a long time your car is very clean, i actually have been working on a CA swap of my friends also lately. I will try to get a build thread of that one up too.splintercell wrote:awesome build and lovin all the new parts
Seriously this is one of the most refreshing comments i have heard on here. I would def put reliability before horsepower. Oh and i got the greddy intake. any tips on shining it up?OM3GA wrote: As well as use high quality parts and make it how I want it to be which is not extremely high hp its clean and reliable.
OM3GA wrote:dude Mrodiek you cut your hair!
Definately missed these comments, Ive been crying ever since.initial_jc wrote:MRODIEKS hair has been cut
I'm glad it helped! More updates hopefully coming later today!TheBlaiant wrote:This update made my day!
