I received a letter from my bank, it told me i should have kept my KA....SR SWAP
mRodiek
Car: Stock Hatch
They do make a kit for the hoses, just so you know.
Why didnt you do any of this while the motor was on a stand?
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Who makes the hose kit?!?! Please show me a link i searched for a good week straight probably before making my own.
I thought about a stand but i just ended up putting it in the car.
mRodiek
Car: Stock Hatch
I cant find it at the moment, I WILL find it for you though lolIf not at least for everyone elses reference.
S13Teddy
Car: R32 Skyline, S13
Should have gotten Tomei injectors. I done heard bad things about dem deatschworks.
Sweet build though, David.
OM3GA
mRodiek wrote:I cant find it at the moment, I WILL find it for you though lolIf not at least for everyone elses reference.
Please do! This needs to be noted, the only reason i started producing kits is because no one else could find them haha. I will believe you when you post the link
S13Teddy wrote:Should have gotten Tomei injectors. I done heard bad things about dem deatschworks.
Yeah i thought about getting Tomei or HKS injectors, However i did not want to worry about a tune right now. I was going to buy OEM injectors through Ray but he said they would take months to get. So Deatschwerks it is for now, they recently came out with a brand new line of injectors which is what i got. Most people were buying their stuff when they were just refurbishing them.
I guess i'll have to write a review of them once everything is running.
Thanks Teddy, cant wait to see your new gangster whip.
bllabong89
Car: 1995 s14
Sick build. Keep up the great work.
It's nice to see a build thread with clean and clear information about what your doing at the time and how your doing it.
P.S. The ending pictures are great and the bold text helps alot to stand out from the average post. Check my build out and give me some pointers. I just like to get advice on what can be fixed or improved and it looks like you know your s***. Good luck with the build bro and have a cold one for the good work
bersh240
bllabong89 wrote:
holy crap.thats my exgirlfriend on the extreme left with the sandwhich.hahahahahahi hated that stupid german dancy thing.
BlackFire240
Car: S13
Liked the NA setup you had... very clean, but the turbo is a must have :D
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Love the random pics, very "refreshing" thread.....People normally cut the lower tube to keep the hose from coiling between the engine and firewall. There are a few kits out there (heavy trottle used to sell one) but you get about the same setup that you already have. You use new hoses and a clean configuration, I like.....
sr_240sx
Car: 1989 240sx w/SR20DET and 2003 Altima SE 3.5L
Nice buil I just end up with mine but mine is a little or more agresive build.
mRodiek
Car: Stock Hatch
Im extremely disappointed in myself. I have 8 million favorites saved for a 240sx and the one I cant find is the ONE kit that was made.
I may not find it today, or tomorrow, or the next day but ONE DAY! lol
Where in Cali are you? Id love to see this swap in person.
snowyred180
Car: 1994 Nissan 300zx TT, 1995 Acura Integra GS-R, 1994 Honda Prelude
Nice build. lol @ pictures at the end.
OM3GA
Thanks, i should be updating more sometime soon.
I'm all over the place in Cali ill let you know if i am going to be in your area.Let me know if you find that hose kit really because for now the only one i know of is the one that i make.
OM3GA
Here is after the injectors were installed!
It took me a second to realize that they were facing the wrong way haha, i suppose they would work either way. Surprisingly enough the plugs seemed like they would have ran better this way but i think the strut bar would have hit them, so they went back to the correct way. You can also see the FPR swivel and stock FPR installed.
Then came the Thermostat in the mail from FRSport.
I was inspecting my thermostat inley housing and saw that there was actually a pinhole in it.
So i bought a brand new one, and on went the thermostat and new inlet housing.
Here i was checking to make sure the jiggle valve did not get touched with RTV on the inside. OCD?
Goodnight!
Modified by OM3GA at 11:38 AM 3/25/2010
OM3GA
Next i got some more new parts in the mail! New crank pulley, new crank pulley bolt and washer!
While i was still waiting for the front main seal, i decided to start worrying about the throttle cable bracket again. After realizing that the stock bracket would not work with the Top speed S14 throttle pulley i decided i was just going to use the stock throttle pulley again.
I figured i would measure the bracket i had already and figure out where the cable mounting point needed to be. I gave Rich at Xcessive a call and had him make me a new bracket with the dimensions i needed. Here they are next to each other.
Here is the new one installed.
Next up was the crank pulley, the front seal came in so that was installed. Then the crank pulley,bolt and washer went on and were torqued to 110 ft lbs.
As you can see in that picture i also replaced the breather hose with oil resistant blue silicone tubing with a special inner liner from Forge motorsport. Great quality stuff, high price but it should last forever.
I also received my oil pressure sensor adapter from NisSport. Great quality however make sure you check for metal shavings inside of it left over from the machining. Mine went on and all together and i didnt think to check until a friend of mine also bought one and noticed shavings in his so i had to pull it off and check, sure enough there was a couple in there but i got them out and it all went back on.
Time to get back to work, more updates later.
OM3GA
Next came my Intercooler i bought a Greddy LS-Spec.
I also got my Greddy hotpipe and cut the hole out for that
Then i mounted everything up, it all fit together nicely.
Everything was going together well, i did a good amount of research to decide on what cooling setup to do and i have always been into the stock mechanical fan setups so that is exactly what i decided to go with.
More parts came in!
Brand new fan clutch!
Brand new Fan Shroud!
Yashio Factory water pump pulley!
The hardest thing in the world to locate was a brand new stock plastic fan, sure i had one but it had a decent amount of stress cracks in it. I ordered a brand new one through 4 different places and NONE of them came i waited 6 months for this item and still nothing.
Right when i started to give up Matt Hodges at the Carisma LLC told me he could get one for me, i couldn't believe it. He is a great guy and the staff at CARisma are all very knowledgable. Make sure to check out their site and if you need help finding anything ask them about it!
http://CARismaLLC.com and their new site http://www.CARismaStore.com
They build some great cars too.
Matt Hodges is "DuckyD" on this forum as well.
So he did find it for me, he wrapped it up real nice before shipping it out to me (Thanks again Matt!).
Here it was
Time to go bathe i'll be back with more updates soon.
Rawrvasour
Car: 89 Piggy
Dude your swap is looking so clean David. This is Chad btw im sure you figured that out by the SN. Looks DOPE ill have to peep it sometime.
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
Really nice. Props broooo
OM3GA
Rawrvasour wrote:Dude your swap is looking so clean David. This is Chad btw im sure you figured that out by the SN. Looks DOPE ill have to peep it sometime.
Thanks Chad, its been a lot of work as you can tell haha. I have been really busy lately and have not had as much time to work on it I will be able to soon though. For now i am just ordering parts and making this build thread haha.
How have you been? If you need anything let me know.
s13beast wrote:Really nice. Props broooo
Thanks man!
S14toRPS13
I like your choice on fan set up.
OM3GA
S14toRPS13 wrote:I like your choice on fan set up.
Thank you, i only like the best for my setups
S14toRPS13
What you planning on doing as far as exhaust manifold and cams?
cali0240
Car: Nissan 240sx 1995 s14
awesome build!!! hopefully "some" day i get to build a rb25det in my s14! that would be my dream car!
OM3GA
As of now i am planning on getting it running with the stock cams and stock manifold. Later down the line i am going to do Tomei Rocker Arm Stoppers as well as Tomei PonCams that are 256/256.
As far as Exhaust manifold goes i will be getting the Tomei Expreme manifold as well. I have heard good things about extruding and honing the stock mani but for the price i would rather have the Tomei.
eazye2000
Car: S13 KA-DET
Wow, I'm a die-hard KA-T guy, but that is looking like a sweet setup right there.
Pardon me, but if that old Xcessive manifold is for sale, please let me know! e_appie (at) hotmail.com
S14toRPS13
Wow, that's almost exactly what I had planned as well. I wanted to get Tomei Procams 260/260, Tomei type A valve springs, Tomei RAS, and Tomei Expreme Manifold. I ended up with Tomei Procams 260, BC springs, Tomei RAS, and an Isis manifold. Some deals were too good to pass up along the way.
OM3GA
Yeah the ka setup was great. Everything from that was sold most of this has been going on for 10 months now. Everything got sold back then to fund the new engine. Sorry man but i can vouch for the manifold as being great.
KA-T is great. I loved my ka but i either was going to have to rebuild it for turbo or swap so i decided to swap now.
That sounds like a great setup man, im planning on not doing anything to the head for awhile any further than doing RAS and Cams. The ISIS manifold is good too i hear nothing but good things about it really. Good choices man!
I will be updating more soon!
J14cm7
Car: 95 240sx S14 SR20det
You've got mail David. Everything looks great. Definitely giving me some good ideas for when i pull mine this winter.
OM3GA
Thank you, i hope you will take pictures and update your build thread this winter also.
TheBlaiant
Car: Slow40sx
OM3GA I look forward more to what the last pics of your updates are gonna be!
