I received a letter from my bank, it told me i should have kept my KA....SR SWAP
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
sulik wrote:Hey mate where did you get your fan clutch + shround from?
I´m searching some for my swap and want to get rid of my e-fans. :yesnod
I got the Fan shroud from my friend Ray at the Nismo Shop. He can also get the Fan clutches, he may still have one in stock right now otherwise get the part number and order it from RHDJapan. They both ship pretty quick :)
Yasko
vvvvvvvvvv
OM3GA
I'm still thinking the HKS mani. I really would love to do the Tomei, hands down but unless PBM comes out with a pipe that will work with it, i will be buying the HKS.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
why not that extrude home and ceramic coat the stock one. it be cheaper. and flow just as good if not better. for 1000 you could pick up a used topmount and pay for part of a turb0
J14cm7
Car: 95 240sx S14 SR20det
Hey david i just test fitted the greddy intake mani on my sr20 and the original greddy cold pipe worked. The other one must be for the greddy TB or something. i will post some pics of both pipes on the car on my thread in case your interested. I hope this clears up some confusion for some people. Keep up the good work and the ideas coming for the rest of us.
Riq
Car: 89 SR SE Fastback
I DEMAND AN UPDATE MEOW!!!!!
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
OM3GA wrote:
Yasuyuki Kazama's D1 S15 Silvia 509HP
Omega, any idea of where I can get the blue or transaparent silicone line used in the S15 SR, I seen it before posted here as JDM product or something like that....
ciscos13
Car: 89' 240sx hatch, s13 sr
Riq wrote:I DEMAND AN UPDATE MEOW!!!!!
agree
OM3GA
Hmm, no idea really. I would try asking RHDJapan and see. I like the clear stuff because it is easy to see air bubbles but if you really want the blue i am sure it can be found. :dblthumb:
I will be updating this thread SOOONN.
J14cm7
Cant wait we thought you died...
OM3GA
Everything is going to be just fine :)
OM3GA
So as you might have noticed i have been very busy and have not been updating this thread as often. :/ Well it is because i have been working a lot and have not had much time to do much more with my build.
Well i will start where i left off.
The next thing i did was install a SARD Fuel pressure regulator. I have heard great things about them and decided to go with this instead of going with a brand new stock unit.
I made a line from both bolt holes on the shock tower in order to create a straight axis which i could like the edge of the SARD mount up with so it was at a proper angle since i was only using one bolt to mount it. Any time i mount something with a single bolt i use Titanium hardware. So i picked up this bolt from Ryan Hampton at Baller Bolts.
Mmmmmm. Burnt titanium goodness. :)
I also hooked up the Fuel return line.
Looks Good?
The Cold pipe was also installed!
Next up was the oil change. I had left the Mobil 1 oil in there because i didnt want to leave it without oil in there at all.
The oil was drained and i installed a brand new Greddy Drain plug(Which i need to find the picture of)
I also bought a brand new dip stick and Stock Oil cap(Oil Cap has the same part number as SOHC KA)(Need to find these pictures also)
I decided to go with the Power Enterprise MAG Power II oil filter which has a magnet at the end of the filter in a cone to catch any metal particles that may get through there.
I have also ran Royal Purple oil in my KA for a long time with good results, changed every 1500-3000 depending on the driving style.
So i decided to go with 10w40 Royal Purple in the SR.
[/b]
Well I guess that wraps it up for now, i will hopefully have some time to find the rest of the images and i should get some time to work on it more within the next few weeks. I will keep you updated with the parts i receive and decide to buy.
Here is also a picture of a CA18DE-T that a good friend of mine has; which we have been putting together for awhile.
Here is something i am considering buying but i am not sure yet.
Have an amazing night
Just probably not that amazing.
kreske
Car: Just bought my 6th S14!!
subscribed.. via post!
OM3GA
Here i am again, i have been busy with work and just got back from Round 1 of Formula D with some good friends of mine.
Anyways i worked on the car a bit last week and got a few things put together.
For my Fuel Rail Fittings i decided to go with the Nismo Adapter fitting.
Since i was running the Nismo Fitting i also have to run the Greddy swivel adapter since i have the Greddy intake manifold.
Without this swivel adapter the nismo fitting is too close to the Greddy manifold and makes it hard to run the fuel line.
O-ring is lubed up with Royal Purple and is ready to get installed.
I lined up everything the way i wanted it and then tightened it all down.
I then ran another fuel line from my SARD Regulator over to the Nismo fitting.
Awesome.
Next up i worked on assembling and mounting my Greddy Catch Can.
Here is the can assembled and ready for action! :)
I had came up with a plan to purchase a Grade 5 titatnium bolt (which i would be making into a stud) with 50mm of thread and a titanium nut which i would be using to mount the can to the radiator support.
I also purchased a few aluminum spacers with the same Inner and Outter diameter but different lengths so i could test the clearance from the radiator support.
I then cut the unthreaded portion of the bolt off leaving me with 50mm of threaded titanium that i would be using to mount the can.
Success!
I threaded the stud into place until it bottomed out by hitting the back of the headlight bracket exactly as i planned which would leave me a perfect amount of thread left to place the spacer,can and nut.
I then placed the Aluminum spacer on.
Then the catch can and nut.
Here is the catch can in place :)
I then test fitted the hotpipe to make sure it cleared the can.
Perfect!
Image :naughty:
I also received my Shift Knob! Keep in mind i ordered this a week before the Tsunami hit Japan. Our friends at RHD are doing well and i hope everyone you know over there is doing fine as well.
Here is the Knob from Yashio Factory! :yesnod
Mmmm Sexy!
I then installed the Knob.
I then measured lined up and placed the Shifter Diagram Badge on the top.
I believe i will be changing my oil over to Motul 300v 10w40. It is supposed to be really great stuff. Let me know if you have used it and have any comments. :)
Stay tuned for more updates coming soon.
I will be working on installing the hotpipe and running the lines for the catch can soon. As well as routing my wastegate vacuum line.
Time for sleeping.
J14cm7
Glad to see this build is back. Always a great source of ideas
OM3GA
Awesome.
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
damn looking real good bro...love the Yashio knob:)
OM3GA
Thanks! :)
georgep
Car: 1989, Nissan 200sx, S13, CA18DET
I just finished reading the whole thing. I plan on swapping my CA18DET for a SR20 soon and the info here will help me a lot. Thanks a lot from Romania man!
OM3GA
Nice first post :D
OM3GA
Well, time for some updates i suppose.
95s14green
Car: 1995 240sx s14
really like your thread! i cant wait to do my sr swap!
Razi
Car: Moo
Lookin good Om3ga! :bigthumb:
OM3GA
Razi wrote:Lookin good Om3ga! :bigthumb:
Thanks you little fuzzball you hehehehehe.
95s14green wrote:really like your thread! i cant wait to do my sr swap!
Thanks for the compliment :D feel free to ask questions or for advice :)
About the updates, i actually fell asleep as i was trying to post them. I will update hopefully tomorrow evening. :laugh:
OM3GA
Alright let me try this again.
Before putting the hotpipe on for the final time; i decided to change the copper washers on the Powersteering pressure line.
I got those two changed with OEM Nissan washers and torqued the bolt to 40 ft lbs.
I then placed the lower hot pipe into place.
Then attached the coupler to the turbo.
Finally the hotpipe :D
So i started hooking up the lines for the catch can and i got one on perfectly but the other side would not clear the hotpipe. I got an angle finder and messed around with a few angles and found that rotating the fitting to 70 degrees from the top of the can would work perfectly.
Looking better :)
Got it all routed the way i wanted it and attached it to the intake pipe.
I also needed to run a boost source for the wastegate actuator.
I am using a T fitting made exclusively by HKS (Thanks Alex :D)
Here it is with two 7/32" Vacuum lines on and secured with two micro zip ties!
Here it is in place under the Greddy Intake Manifold
I also have attached a 5/32" Vacuum line which is running to the Boost Gauge adapter for my Greddy Informeter Touch.
From under the Intake Manifold i ran the 7/32" Vacuum line up and along the front of the valve cover.
I then ran it down under the hotpipe
Along the side of the strut tower
Finally up and attached it to the Wastegate actuator :)
I then mounted my new OEM coolant resevoir and that is where i left it.
I am looking at batteries and mounts and will most likely be going with a Braille setup.
I am switching my oil to Motul 300V Chrono 10w40 and the Transmission and Diff fluid to Motul Gear300 75w90.
We have recently started running those fluids in my friends CA powered 240 as well.
Please give your feedback on the Fluid if you have had any experience or heard anything about it.
Hope you enjoy the update.
Time for bed
TheBlaiant
Car: Slow40sx
I loooooooooooooooooooooooooooooooooooooooooooooooove shaved valve covers ;)
OM3GA
They are pretty awesome :D
Theway2be
Car: 93 s13 hatch
Awesome build! :bigthumb:
Do you have the same thread like this for Ka24 motor? I am researching on building a ka24 motor to 350hp or higher, and have some fun before committing to sr20.
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Very nice build bro. :dblthumb:
OM3GA
Theway2be wrote:Awesome build! :bigthumb:
Hey Bud, thanks a lot! I actually do not have a build thread for the KA. It had a lot of top name parts but the internals were stock. I set that motor up when it was around 189,000 miles just to make it the way i wanted it and see what it would do with the parts i put on. It was a lot of fun.
What are your plans for the KA build?
Lobo240sx wrote:Very nice build bro. :dblthumb:
Thank you! :) It has came a long way and is still coming along as planned.
