I checked the wiring right after and it checked out, i was confident in it but everyone told me to start there. and yes the iacv is still there, the motor ran perfectly when it was pulled out of the other car so idk whats wrong now. i think its the MAF, but no one by me as a 240 so i cannot swap them. when i start the car it runs rough and smokes really badly, but its grey/white and not blow or anything like that. and Hoffman if you dont have anything substantial or helpful to say id rather not read it, i posted in here first because i figured someone may have had this problem before and could tell me what it is before i go off and check through eerything when it could be something basic.Hoffman5982 wrote:so...you aren't confident in your quality of work on something, but instead of checking it you go through the trouble of uploading a video and starting a thread on here?
Stop being a d!ck.Hoffman5982 wrote:so...you aren't confident in your quality of work on something, but instead of checking it you go through the trouble of uploading a video and starting a thread on here?
I'm sorry, but how was I being a d***? I was simply pointing out that even he questions himself on something yet hadn't checked itkrash wrote:
Stop being a d***.
Yea thats true. Its got to be something wrong on the chassis if you said the motor ran perfectly fine when you pulled it. Did you remove the emissions stuff after you pulled the motor? Double and triple check everything if you did.allenms240 wrote: Krash, if the engine was flooding out, wouldn't it not start up again as soon as it does in the video? Wouldn't it just crank away, trying to ignite all the fuel but failing.
hoosier240sx wrote:i can't really check the ECU for codes because when you swap a DOHC over to a SOHC chassis you have to cut the diagnostics plugs from the dash harness.
Yeah dude definitely send me that cause I'd really love it have it. And I am almost 100% positive it is not a vac leak there is no reason why it would run until it warms up and then bog out and not start again. It just doesn't make sense....moso wrote:hoosier240sx wrote:i can't really check the ECU for codes because when you swap a DOHC over to a SOHC chassis you have to cut the diagnostics plugs from the dash harness.
you can wire up the diagnostic plug where the harness goes into the dash harness, just snag a plug off any like year nissan the TX and TX wires are the same color in the plug as in the ecu harness, then you just need ground and power and your set. I made a walkthrough a long time ago and got flamed all to hell for it because "thats old news", guess its not old to some aye. anyways you can just set the ecu into code mode from the dial on the side of it and watch the light. if you need the walkthrough for the diagnostic plug i can send it to you as i have done it to my car and i have a dohc swap....with consult!!
hoosier240sx wrote:The big hose at the very bottom of the intake goes to the fan shroud for the radiator and is irrelevant on the DOHC motors. Thanks for the time and effort you put into the video though I really appreciate it.
Thats actually a resonator to quiet things up IIRCallenms240 wrote:That hose (mines is just plugged off) goes to a box in the fan shroud correct. It is used so that if water gets in the intake, it can drop down into the fan shroud, where if won't do any harm, as opposed to getting into the motor.
I'm not sure chief. Both 240s (factory specs) I've had haven't had them. I've only seen that screen in one 240 MAF and an altima MAFs, so I don't think its really integral to the function. I figured it was just for catching extra crap.compactfean wrote:Yes those screens are very important to prevent turbulence. I know from a6 month diagnosis I did.
That sucks. Lets hope the ECU works? I'm stumped man.hoosier240sx wrote:I changed the MAF out with my buddies and it wasnt the problem, the car still runs like complete a**. I'm legitimately stumped dudes, the last thing I can think of changing before i go and tear my wiring harness apart would be the ECU. I really want to know how to wire up the Diagnostics, I wish Moso would get back to me on how to set all that ish up...
