I really like these wheels, but will they fit or can I make them fit?
Arashi
Car: '93 240sx LE
Okay, I've done some searching and know what I'm up against. But my problem is I'm REALLY fond of the look of these wheels:
Even though the image shows 5 lug, they are available in 4 lug as far as I know.
So far I can only find them with a 42mm offset (though I've only seen it ina few spots so far). the size of the wheels are 17x7 that I want, I also plan on getting megan street coilovers eventually. I don't plan on changing my fenders and I REALLY don't want to roll them for some reason. I'd also like to make room for 300ZX brake calipers later on, even though I'm currently stock.
Would you guys know of any other places that may have this wheel with a different offset? Otherwise how would I make these work, and make them as flush as possible without rubbing and fender rolling?
I'd assume I'd want to tuck them in ever so slightly so they miss my fenders, and I may have to relocate the harnesses under the front fenders.
All in all, I guess I'm looking for clarification so I can get my measurements in order, and see which route I need to go for these wheels to work!
hannibal
Car: Red Line to Glenmont
No offense, but thats a really crappy size. Those will sit 5-6mm closer to the coil than 17x8 +35, and the 8" wheel is VERY close.
Try to find something at least 8" wide with a lower offset (under 30-35). But you could always use a spacer with those Motegi wheels if you just have to have them...
Arashi
Car: '93 240sx LE
According to Ttire rack, these SHOULD fit without a spacer at that size and offset.
I should be able to get these wheels in a 5 lug pattern with different offsets (according to thier site)
if I get a 5 lug conversion, I heard I may lose the use of my ABS, is this true? If so is there away to NOT lose ABS?
Also what would the bolt pattern be for a 5 lug conversion if I do persue that route?
whiterps13
Car: white LE hatch
They will fit without spacers if you run a 205mm wide tire. If you run 215's you will be extremely close, but 225's will rub.
Search for some differant wheels that are actually designed to fit your car.
xyoufailmex
Car: 1990 240 FB
He wont be anywhere NEAR the coils with that pathetic width.
Get a wheel made for your car y0!
Arashi
Car: '93 240sx LE
That's my problem, I'm having trouble finding wheels with <30 mm offset
Are there any wheel sponsors for Nico?
hannibal
Not a sponsor, but this site has good search function. But they dont have a lot of good looking wheels IMO.
You just gotta look hard for good fitments for the S chassis. MB Motorsports, Hot Wheels, Sportmax, and 5Zigen make some good sized wheels.
Arashi
Car: '93 240sx LE
Thanks for the names, this should help me find what I want!
