Robi1 »
https://forums.nicoclub.com/robi1-u56059.html
Sun Sep 09, 2007 9:42 pm
First when you replaced water pump was system flushed prior to new pump going on?. Was gasket placed on the right way? second was the system properly bled of air, somewhere by the thermostat housing will be a small bolt or hex grub screw to bleed the system of air also possibly 1 on front of block &/or head. If you cant find one, remove radiator hose from thermostat & hold hose above height of radiator, then fill untill water just starts to pour out top of thermostat housing look for air bubbles. replace hose to thermstat, & remove top heater hose from where it enters firewall & hold it above height of radiator, fill with water untill fluid runs out heater pipe (make sure heater tap turned on) then have some one crank over motor (dizzy disconnected) look for air coming out, keep pipe topped up with water, when there isnt any air bubbles visible replace pipe. then look for grub screw on head/thermostat area open and repeat process untill no air visible. replace. fire up motor and look for hoses bulging if no bulging fine. If continues then either radiator recore is necessary or ther is blockage around water pump, if you were observant while someone was cranking motor on the bleed process water should've been pumping well. if not then remove pump and flush system, replace. to check radiator remove it then backflush with cap on if ther is good flow then radiator is fine if not then your up for new radiator. Even when they've had antifreeze they can still clog up. hope thats been helpful for you.
