4cefed »
https://forums.nicoclub.com/4cefed-u1486.html
Fri Nov 08, 2013 8:43 pm
I've been neglecting my poor '92 coupe 240SX. I needed wheel bearing in the front and there were a lot of clunks and rattles up there too. I ordered new wheel bearings, new lower "control" arms, new T/C bushings, tie rod ends, sway bar bushings, end links, and strut mounts. Since I (used to) live in Vermont, I never worried much about fancy coil-overs since they will be too low or destroyed in months on those roads. I got a set of generic Gabriel shocks from *shudder* Autozone about 4 years ago.
The front passenger side shock blew out like a year a go and it must have gotten water in it, every time the temperature dropped I had zero suspension travel on that corner til it warmed up a bit. I brought them back to autozone and exchanged them for new ones on the lifetime warranty.
So everything went ok, I found out my 6 ton bearing press must be mounted in a 2 ton frame (pics to follow), and the only difference was in the strut tower mounts. I believe I had the originals in there with almost 200k miles. The new MOOG replacements looked almost 1/2" taller. I looked up part numbers to confirm I had the right ones and i did, so I figured my old ones must have been compressed over the years.
When I got the car back together and put back on the ground, the front seems to be riding almost 2 inches higher. I re-used the same stock springs, and other than being a bit higher due to the strut tower mounts, I'm totally lost on why this would happen. Could all the new bushings cause it to sit higher? Sorry for the lack of pics, I'll take some in the light tomorrow while I do the alignment. I'm looking for some ideas though. Thanks!
4cefed on Sat Nov 09, 2013 1:23 pm, edited 1 time in total.
