Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Mon Sep 09, 2002 7:10 am
Plenum hoses, 120k service, oxygen sensors, driveshaft, new shocks and boots, two sets of tires, all brakes, sunroof rail replacement, upper links, tension rods, all new bushings, oil pressure sender, rear diff bushings, 2 lower traverse arms,, one lower link arm, one rear camber arm and new eccentrics, and radio R&R.................the next 12 months were down to $5,800, then $4,000 then $3500 so $20,300 in only 4 years the last year thru June was around $3,000 but that included the $600 I paid for half a wrecked 92 Q.
So $23,300 for 138,000 miles is only 16.8 cents a mile but I have roughly $2,000 in spares in storage.....summing it all up around $34,000 since June of 1990 about $2750 per year give or take
Last year [June 2001-May 2002] I changed the differential, rear subframe, and two bearings and 2 hubs that was $1500 alone [$4,000 at retail pricing].This year June 2002 -- $600 bought an almost new transmission, a new compressor, new dryer, new condenser, new battery, 2 new headlights, an entire dash, all electronic modules, $1,000s of misc items.
Somewhere back in history was the custom all aluminum radiator [Summer 1999? 160k] that was 78,000 miles ago.
Lots of things on the car should last another 100,000 miles. {will the engine make it to 338k? My orginal plan was only to get to 250k only 12k to go.
I sure many have gotten close to 200k and not spent half but mechanically I am a perfectionist!......body and interior is another matter!.
Now that I am only driving 15,000 miles a year things don't seem to wear out!
For the last 15 months I have been buying parts from junk yards or wrecks but I 'm sure I'll have to pony up to the dealer trough in the next 9 months.Found a set of front Metal Master brake pads for $32 will need new rear rotors by Xmas. New plugs in 22,000 miles ......flushed the powersteering pump/rack system today it is the oldest rotating item that hasn't been opened/replaced at 238,000 miles
