jr_ss »
https://forums.nicoclub.com/jr-ss-u34795.html
Mon Sep 11, 2006 1:25 pm
Wait you pulled the wastegate vac line off? Or you disconnected the wastegate arm? Either way doing both of those things could cause serious damage to the motor/turbo. Wastegate vac line off, you're going to max out the wastegates capable psi. Wastegate arm disconnected you're going to over spool the turbo and cause some serious havoc to your motor...
