:: orion :: wrote: And the shims are dirctly under the cam lobes...the metal discs you see. They kinda stick in place with suction, but can be removed with a tiny screwdriver or magnet.
I mentioned this to Greg in another thread, but that's the one reason I'm reluctant to do some aftermarket cams (JWT or PDM cams). I'd feel compelled to check my valve lash, which in and of itself is tedious. If one or more of those suckers is out of spec, those little bastards are really expensive. I can't believe how much Nissan charges for a small metal disk.
Would you agree that it's probably wise to check valve lash if you're doing cams anyway? I know JWT recommends it, but I don't know if that's overkill.
If it were you, would you check lash, Brian?
