i put a 302 into my 240sx but..... need help with some thing...
maik21
Car: 90 Nissan 240SX Coupe 5.0
well... now... i have some thing that i havent repair yet, but.. ...
the engine is carb 5.0 l ford...transmission AT c4 ( overdrive )
i think i only get a top speed of 140kmph ... i dont have guages... only temp and tacho.. but.... can i do more top speed changing the diferential? if i can do that, what type of diferential is recomended? maybe one of a 300zx turbo? well.. thanks for help =)
atte maik
574-240sx
Car: Nissans, Toyotas, Subaru
pictures?
Sounds like you need much longer gearing.
maik21
574-240sx wrote:pictures?
its dirt now.. but ...
i have a video of the engine... give me your msn to send you =)
240DRFT
isnt 140kmph like only 70mph?!?!
naed240sx
Car: .....
240DRFT wrote:isnt 140kmph like only 70mph?!?!
240kph=87mph
maik21
yes... aprox !!!!
240kmph isnt 87mph because the odo of the 240sx say 110 mph at aprox 180kmph
240DRFT
i guess im a good guesser
a 300zx turbo diff should change the gearing a little and give u a higher top speed
maik21
are you sure?? and what other things i need to do a correct swap?
naed240sx
Car: .....
maik21 wrote:yes... aprox !!!!
Sorry, obviously I didn't mean that. I meant 140kph=87mph.
Yeah, maik, a 300zx tt diff will definately lengthen all of your gear ratios. You can also run very large tires as well to help out.
maik21
thanks.. but... is it direct bolt on?
unstable240
Car: OG RB20DET
Yes the TT Diff fits... Just longer gearing...
240crawler
Car: 1991 240sx
Are ther not any custom gearsets around. He could use a 3.42 or higher intead of a 4.08. Plenty of torque to cruise around, and one hell of a run on highway.
maik21
thanks... i try to find the tt diff here in mexico =) thanks to every body =)
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
Isn't there a way to just swap the final drive or something like that?
The Mustang aftermarket is effin enormous, and I imagine you're using a Mustang transmission, there have to be aftermarket final drive gears out there.
naed240sx
Car: .....
Yeah, he could probably find an aftermarket domestic diff and ring gear, make custom mounts, get a driveshaft and axles made, and whala.... but that would be pretty expensive. I would imagine that the easiest thing would be to use the tt diff, or have a custom ring gear machined for you. Someone should do the math on the tt diff, See what kind of a difference in gearing it would make for this guy. If it turns out to be not enough of an improvement, custom parts would be neccesary.
maik21
i dont know, but here, all the stuffs can be done ....
i found this in the page 240sx.org ...300ZX 90+ Turbo Needs new output flanges and gears are lower ....
what it mean?? gears lower... em... less top speed?? and what with the output flanges?? isnt direct bolt on ?
rexhunta
Car: '95 Mitsubishi RVR ( 4G63T and AWD thanks !)
MY10 Forester X LE
You need NOS.
And Maik, you need it by tonight.
240DRFT
but nitrous oxide isnt for amateurs. ive seen the way he drives, hes got a heavy foot.
dickie
Car: Killer Turtle
hes already running enough NOs to blow himself up...
240DRFT
its not how you stand by your car, its how you drive it, he better learn that.
maik21
hahahahahajajajaja... youre so funny but ....
i dont think i need nos, because the top speed is so low and i dont need an blown engine =) i need more speed without going into red zone !!! but if you said that diff tt 300zx will fit ... i need to search for prices, but here in mexico, the prices are lowers cheapers ... and i some of you told some thing... big tires.... maybe it work to, but what kind of tires i can put?? im now 195/60/15 !!
dickie
Car: Killer Turtle
dood if you can get the parts cheap down there score me an lsd too. im in tx so its not THAT far...
maik21
hahahahahahaa, iep.... example.. i buy a 91 front bumper for my car... it cost $90 bucks and go directly to my home. Shipping Service free =)))
maik21
with this 302 carb and that crapy transmission, i now beat stangs 4.6 and 5.0... stock stangs ... and my engine is stock 2!! maybe or truly all of you think that this is now good, but its a good inprovement for my car and it has cheap parts for repair... and other things ... now open diff sucks..
maik21
my car .... dont put atention to the window words...
i have a video of the car with the hood open... give me your email if you want to see the engine....looks dirty but its ok.... and other stuffs wrong.. the video movie file is aprox 3.5mb
jrsink
try car-parts.com
i wanna see too...
jrsink
try car-parts.com
i wanna see too...
maik21
give me your email address =) and i send you!!
jrsink
naed240sx
Car: .....
[email protected]
me too!
thanks
