midnightsliding »
https://forums.nicoclub.com/midnightsliding-u8138.html
Wed May 16, 2007 12:22 pm
and i need my car running agine.
so i was coming back home from work, and my car started bucking like it had a boost leak/ and or it was running out of gas or something along those lines. so pulled over and it had really low/shiiiitty idle. then i cut it off and once i cut it off it has not cranked back up since. it turns over and catches like its about to start but then continues to just turn over. im pretty sure i have fuel/ its registering 40 psi when the key is forward, and the fuel pump is on. have not checked spark. or anything else i have to get it back to my shop some how b4 i can really work on it i just wanted to see if their was something to look for.
set up isRB25det into a Q45. SAFCII.Q45 mafs, T3t4 turbo, stock exhaust manifold, FMIC, stock injectors. ill get a video up tonight if i remember to get some batteries for my camera. any help will be ****ing rad. thanks a head.
Modified by midnightsliding at 2:33 PM 5/21/2007
