I polishing a valve cover. need opinions!
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
Like I said, im working on polishing a spare s13 kade valve cover, and if it turns out right Ill sell it. Should I shave the letters?
Also, any tips on sanding and polishing around the letters if i choose to keep them?
MR.chris
Car: 1995 Nissan 240sx se SR20DET Money Pit
Just use paint stripper. You can get it at at auto paint supply store or at lowes etc... And keep the letters.
ashibah83
Car: 93 SUPA BLACK COUPE
MR.chris wrote:Just use paint stripper. You can get it at at auto paint supply store or at lowes etc... And keep the letters.
there is a difference between polishing and removing paint.....
use rotary tools, small grinding wheels, like a dremel
wishin_on_an_sr
Car: '89 hatch and '92 coupe
^what he said. i polished my manifold with a dremel and a wire wheel. you can do a valve cover this way. id say leave the letters. id suggest clear coating it, however im not sure if it would hold up to the heat haven't had a problem with my mani though
the hardest thing other than the letters are little stress cracks or something in the casting. Im down to some heavy duty emory cloth getting these things out. I hope this comes out nice. Thanks for the input guys. I read an article on using a dremel and using self adhesive sand paper and making little cones to sand in tiny areas. going to give that a try.
