M374llic4 »
https://forums.nicoclub.com/m374llic4-u35918.html
Sat Jul 15, 2006 12:02 pm
Which im sure you are aware of, and had to say it so that the post was able to be in the CA forum.
I just really wanted boost_boys opinion instead of the bunch of a$$ in the other forums.
My drivers rear lower brake bolt, i ripped the head off of it a few minutes ago trying to replace the brakes. I was able to pivot the caliper in order to take out the old and put the new brakes in. I can not get the caliper off though to try and drill out the old rest of the bolt, but since its tight in there and wont come off at all anyways, I just tightened the top bolt and its just as sturdy as with both.
My question is, what should I do???
Can I leave it as is since I cant even get it off my self, so I doubt it will fall off or anything, since it has both bolts through it and is really tight, I just have to pivot to change brakes?
This is a good time to do a 300zx upgrade, but dont have the money. And cant even get it off.
Any suggestions?
Also, I was sitting in the parking lot with the radio only on, and i shifted it in to 3rd and the transmission made a springy sounding pinnnnggg.
ideas?
Modified by M374llic4 at 3:27 PM 7/15/2006
