I ordered my s-14 sr today from japanstarmotor
pauliedrft
Car: 91 240sx
they were very helpful and was ready and willing to take my money , they did a compression test and dry came up 149psi on all 4 cylinders . i told then to me that was not acceptable and it should be over 150 psi on each . he said give me a half hour and ill have another engine picked out and have a new compression test done well they could have gotten away with it until the scratches on the (new ) clean motor were identical to the first ones and they had gotten a little oil on the heat shield to me showing a wet test . 152psi on each, i give them 1 star for honesty but i already pay pal'd them what do you think of these number ? i know 128 psi is very minimal and 155 is good from the searches i did . I sent an email back calling them on it .well see what happens .
CoupedUp
Car: 1993 Coupe
You have to remember that there are variances from gauge to gauge...if they have a cheapo deapo gauge it could read high or low. The main thing is that the cylinders are consistent which shows you that the rings/cylinder walls are relatively consistent and that the HG is good in its current state.
fast_s13
you gotta remember they are doing it on a cold motor . prolly arent holding the throtlle body open. it will read higher on a warm engine with t/b open
757coupe
i thought you were not suppost to see numbers in the 150's on a cold test your just looking for consistancy throughout all 4 cylinders. Its not untill you do a test after the motor is warm up that your suppose to see those numbers............correct me if im wrong. when i got my sr i did a dry test by manually turning the crank and i got like 120 but it was the same for all 4. how did they do the test, did they hook it up to a battery and **** or did they manually turn the crank.
CoupedUp
Car: 1993 Coupe
You cant manually crank for a compression test.
aznrib
Car: 1995 240sx
leak down test is the way to go.
pauliedrft
Car: 91 240sx
Well here what was sent to me .From: [email protected]: Thu 1/22/09 2:06 PMTo: Paul Nordaker YES IT IS THE SAME WE DID COUPLE OF MORE THEY WARE UNDER 120 SO WE DID THIS ONE MORE TIME IT CAME ABOVE 150ALL TURBO ENGINE THEY DON'T GO OVER 160 EVEN IF THEY ARE BRAND NEW IF YOU HAVE ANY PROBLEM WITH THIS ENGINE LET US KNOW WE WILL SEND YOU ANOTHER ONE WE SELL OVER 40 ENGINE EVRY MONTHS WE KNOW THE CONDITION OF EACH ENGINE WHEN YOU RECEIVE THE ENGINE OPEN THE OIL CAP YOU WILL SEE THAT IT IS A VERY CLEAN ENGINE IF YOU DON;T LIKE IT CALL ME BACK.Japan Star Motor, Inc.http://www.japanesestarmotor.com(877) 482-3777
(SORRY I HAD TO EDIT IT I MISS READ HIS MESSAGE AND IVE ONLY HAD 3 HOURS SLEEP ) Now im going to hold him to his word . i just want a good motor set this is my first turbo set up (so my cherry is finally getting popped lol ) and i guessing it is cold but why did it go from the 149 to under 120 and what did they do after that to get the psi up ? i dont know And at least hes trying to work with me because im so dam anal about **** especially 2500.00 dollars worth .And it was a matco compression tester both times . And he must be pissed all caps lol Open the oil cap im pulling the pan and checking the riod bearings and main bearings . the day it gets here .And the valve cover is getting pulled offf to Cause im going to be polishing it anyway. It got shipped today and should be here by Wednesday next week .Thanks for the imput guys
Modified by pauliedrft at 5:27 PM 1/22/2009
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Be careful, Some suppliers will void the warranty if you go into the block/head. I don't think valve cover or oil pan will be a problem but they might not like the rod/bearing caps took off. If you are taking them off you might as well buy some new rod bearings and replace them while your in there.
GL!
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
149psi on all cylinders is very decent compression #'s...I would be perfectly content with those.
pauliedrft
Car: 91 240sx
supreamS14 wrote:Be careful, Some suppliers will void the warranty if you go into the block/head. I don't think valve cover or oil pan will be a problem but they might not like the rod/bearing caps took off. If you are taking them off you might as well buy some new rod bearings and replace them while your in there.
GL!
im going to try to move the rods by hand looking for play in the rods if it moves to much you know something is wrong . If everything looks good ill put the pan back on there see im not even going to be installing the sr until way later this year so the 30 day warrenty will be out the question so i need to take what measures i can to make sure my investment is protected .
240life
240life your so right but like i said my cherry is just going to be getting popped i did not know that low psi compression like this is ok for a turbo motor ,to many people get screwed over because of the shipments and abuse of these motors ; i mean enjuku does not sell them anymore for this reason i posted an email from them a few months ago .So by me pushing the envelope they made sure to give me a good motor. (But what would cause this high of psi doing a dry compression test a few people have said 120 is normal. )So i guess ill have to wait and see .So far everything is going ok and hopefully we can have these guys a a good company to buy from especially for the price of there engine sets and the free shipping to my door with a lift gate i cant complain about that . Honesty is upgraded to a 3 1/2 stars and customer service( 5 out of 5 )price 5 out of 5 ,ill give my opinion on the engine when i get it .Dam i cant wait to finally be boosted .
240life
it really depends on how long the engine was sitting. If the rings and cylinder walls had not dried up etc... I would say 120 would be a gamble but if all cylinders were within 2-3 psi of each other it would indicate a decent engine. I would definetally request a test with a tsp. of oil added to the piston area and go from there if my compression initally tested that low. It sounds like you should have gotten a decent engine...hopefully upon opening it up you will be satisfied.
CaEric
Car: 91 Sr Pwred Coupe
if this is the place in albany ny ,.,.....i went there to pick up my motor......so when i get there they tryed to give me a ****ty looking motor with a broken cas.....and choped harness......so i was like i want a diffrent motor.....so they picked adiffrent motor out and the compression was real realy low on dry start with a battary.....i pickedout a diffrent one after that and he like no no u cant have thaton...so i was like f this and was a bout to leave and he like fine u can have it....it was agolde motor : prefect acrross the bored...u have to watcth em guys so in my way home i seen that it had the wroung ecu.....i i was like wtf.......i had a sr2ode ecu......so iwent they sent me a j4 ecu...still the wroung ecu....but i said fit andwire the j4 up and called it a day......they didnt realy have that maney sr20det in there ware house...lot of honda motors that looked popy
pauliedrft
Car: 91 240sx
And this is why im a diKK, im not going to play there games; i paid them for a good motor . Does anyone know what ecu's i can use with the notch top i need to know before it gets here which is this week its sitting Kansas city right now. So may be here tomorrow .
What is a agolde motor ??
240life
http://rds.yahoo.com/_ylt=A0ge...42286 Lists all of the codes for any sr20det ecu
pauliedrft
Car: 91 240sx
240life wrote:http://rds.yahoo.com/_ylt=A0ge...42286 Lists all of the codes for any sr20det ecu
Dude thats awesome i really appreciate it . and it looks like it s in transit from kc at like 2 am this morning (Damit i was hoping it would land on one of my days off but sighs at least i get it earlier ) so i guess i will be waiting for a phone call from a driver lol
nzmoman
Car: 240sx 2 of em' and always lookin for more
this is why i am never apposed to buying a motor from someone locally. You can always get a little history and even though most local private sellers don't provide warranties, you can run the compression and leak down tests. and in some cases you can see the motor in a car before its pulled and given to you.
But with the sheer number of SR's being shipped across this country I would imagine that you will not have a single issue.
pauliedrft
Car: 91 240sx
well i give these guys 6 out of 5 stars for there free shipping cause in getting it delivered by a smaller truck with a lift gate to put it right in my garage . i figure aroung 400. to 500. for shipping so i paid 2000 or less for my s14 notch top engine swap .no complaints here so far .
fiznowler
Car: 97 240sx se, 5 speed, paint, tan leather interior. vg30dett swap in progress.
86 300zx NA Daily Driver
Too many other nissans and parts to list!
They must have just barely missed the ice storm here! I am in the planning state of my sr swap right now. I am hoping to have everything together this summer. We will see though.
Sil80315
Car: 1991 Nissan 240sx
I have also been to their albany store in NY. Ive purchased a few sr's from them already but I personaly go there and hand pick them myself and im usually there for a few hours to make sure im getting the best they have.
Sometimes they can be kinda shady but you cant point to the workers cause all they do is what they are told and thats putting the motor on a pallet and ship it out and most of them don't know much about each motor cause they carry pretty much every import car engine.
As for the compression check..usually all they do is do it dry then add oil and aslong as the numbers are all the same you will be fine.
Their prices are pretty nice. the cheapest I got an sr from them was an s13 blacktop for 1600 with the full swap.
take pics when you get the motor
pauliedrft
Car: 91 240sx
Yeah im planning on it , well its sitting here in springfield mo right now just waiting for the call for them to deliver it to my house . which i was shooting for tomorrow we will see im not even droping this thing in until this june or later anywaty cause there is other things i want to do to the engine . but ill post up picks as soon as its in my garage .
Jah1mon
Car: s13 coupe
I was planning on getting a SR front clip from them this spring, let us know how the engine is once it arrives. Just curious to know how the overall experience was.
pauliedrft
Car: 91 240sx
well i got my ecu coil pack cover broken ,boost silinoid and my kaaz 2.0 lsd came in just moments ago andd my meagan mani but my ecu numbers are (red) WC 23710-69foo so i looked at the list and its for an s-14 93- to end what ever that means .
Jah1mon
Car: s13 coupe
The coilpack cover broke in shipping?
That ecu number seems to correspond with a s14 sr20det engine.
Clain
Car: 1991 240SX - s14a SR20DET Swap
If anyone is in the MO, IL, KS area i'd suggest getting ahold of Dewy from http://JDMHookup.com . He just left for chiba to fill up a container or two of engines and parts to bring back, so he's gone for a month. I just got my kouki s14 sr20det from him. Awesome guy to work with.
pauliedrft
Car: 91 240sx
Well im finally going to get my engine set monday morning between 8-9 am they were going to deliver yesterday but then called back saying they didint have anyone to deliver such B.S get my hopes up and they screw it up some how . they had it for almost a week now and Monday will be . So frustrated , but it gives me time to get my garage set up to play with my new toy hehehe .
painengaged
Car: s13 sr20det
i didnt like the people i got my motor from
pauliedrft
Car: 91 240sx
Who did you get your motor from ?
