i opened my valve covers today
blk90s13
and thats wut i found in there
Nameless EJ6
Car: What the **** do you think.
Cool. What're the specs?
Carl H
that proly explains the erratic idle, hks cams dont idle well unless you have idle at 1k rpm, my buddy has some in his ca and below 1k the car tries to die.im guessing they are either 256/8.5mm or 264/9mm cams, proly the latter considering how much work was done to the engine.
Eikon
Car: 71 240z, 93 Supra TT
Guys, can I ask a stupid question... I haven't been able to find the answer on NICO or other forums...
I want to add a little "Bling" to my engine bay... so I thought some high-temp engine enamel on the valve covers would be sharp! Obviously removing the covers isn't hard... but putting them back on leads me to a couple questions...
What are the torque specs for tightening the valve covers back down? Also, where do you get new valve cover gaskets? I checked out McKinney, Phase2motortrend, etc... no luck? Can I just reuse the existing one assuming it comes off clean?
Thanks!!!
blk90s13
the valve cover is held down with a philips head screws so it was not hard to take off one hand twist and they all came right off
the gasket looks like it can be easly reused imo
all i found is a full gasket set and i really dont need all of the gaskets yet
now i should be able to tell wut cams they are from the dyno power band right ? and then i should have the cam gears adjusted according to that
and yes HKS made eithe a 264 or 256 only i already called them
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I hate show off's lol j/k.
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
Heres some bling:
blk90s13
Slo_240sx wrote:Heres some bling:
did u do that ur self ? i need to paint mine black but i am no where as talented with spray paint as that pic
Sil240
Car: Nissan S13 "The One Cam Wonder"
Mo I thought you painted them already??Did you use High temp engine Paint and a clear coat?
blk90s13
no high temp and yes i used clear
here is a pic ( the lighting suck they look alot better in person )
CKs240sxNC
Nice luck, if only it would happen to all of us
Sil240
Mo you have GT-R injectorswhat's up with that resistor pack????DAMN you
blk90s13
Sil240 wrote:Mo you have GT-R injectorswhat's up with that resistor pack????DAMN you
thats the injector`s resistor and its wired up in the harness
if u notice the coils are all numbered ?
every thing on my car is like that all the plugs is marked no clue why the japs did that but it looks like they made this whole harness out of scratch
