I didnt mean to say that i meant to say you want to remove the cams? if you are trying to JUST remove the lifters then you do not need to remove the cams at all..you just remove the rocker arm pads which sit over the cams, on the lifter and on the valvesprings..just pop that off and the lifters are right thereS13FASTBACKSR wrote:so you want to know how to get the cams out so you can get to the lifters?
