I neeed help ASAP
240_dude
Car: nissan 240sx
Well guys i have a problem my 240 is not starting, its not turning over. I checked the fuses and the battery. Its not even turning over when i turn the key its nothing.Could it be the saftey switch, Starter, or the altenator. I know the motor is not blown or anything like that cause i was driving it but then when i parked it and came back 3 hours later it wasnt turning over
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
Sounds like a bad starter to me, have a friend hit the key while you tap on the starter with a long scwewdriver or something. Sometimes you can get the armature inside the starter to rotate off the dead spot that is causing your starter not to function. If that dosent help break out your multimeter and check for voltage while your buddy hits the key. Either way the starter is probably bad. Hope this helps
Modified by moso at 6:02 PM 9/1/2009
240_dude
Car: nissan 240sx
I swapped the starter out and still nothing i check the voltage too it seems ok.
moso
90 240sx ka24de RIP
Did you check both wires, signal and constant? Can you rotate the motor with a wrench by hand? Auto or manual? Is there water in your oil?
240_dude
Car: nissan 240sx
Dude it was the clutch saftey switch or nuetral switch(its manual lol) the moron who previously owned it drilled a hole through it and he came up with some bs saying that it was for saftey reasons so i just put a nut there and it starts up like a champ
moso
90 240sx ka24de RIP
sweet, never would have guessed that.
240_dude
Car: nissan 240sx
yea man, but now i found out i got a rod knock like no tommarow. so im just gonna buy a rebuilt new motor. BTW how long do they go for?
