I need your suggestions on a idle problem.
skygtr
Car: 240sx s13
I took my car in to get the timing chain done; when I got it back it idles like ****. When you let it idle it goes from 700 rpm to 1500 rpm and back to 700 rpm then back to 1500 rpm, then it dies if you don’t give it gas. They said that they put it on right, and they still can figure out the problem. So what could the problem be, or suggestions.
1993 240sx ka24de.
Modified by skygtr at 2:59 PM 7/24/2007
Chukidori
Im having a similar problem except it doesnt die, it will go from 700 to 1500 and then shake real bad like only 2 cylinders are firing.
I was told it is MAF related. Unplug your maf and see if it stops it. But dont drive it like that...
skygtr
Car: 240sx s13
It wont even idle if the MAF is not pluged.
180fan
Car: 89 fastback
did you check over your iacv, pull the plug on both the mafs and tps?
skygtr
Car: 240sx s13
What else can it be if the mafs and tps are good.
