dammit, i wanna come there and bittch slap you!!ILikeMy240sx wrote:I mustve turned it about 100 times but it wont even budge...
I thought that was the name of a company founded by Rosie O'Donnell.....sanioll wrote:
ITS CALLED RENT A TOOL SOMETHING.
I did not take the line off... so I don think Id have to bleed the brakes.hudy wrote:make sure to bleed those brakes!
huh?bayareastunna wrote:ok well for starters my car wont turn over and start so i compression started it...and it ran fine but im having a problem with my temp gauge it runs hot in about 20 minutes im thinking it may be the water pump...i just replaced the fuel injectors...i also put in new spark plugs bosch to be exact and i was reading a couple of post on here saying that they were really crappy spark plugs for a 240 sx im wondering if that could be the reason why it wont turn over?
Both S13 and S14 has the piston that needs to be turned. I do have the tool to turn it but no I do not have the tool that BOTH turns it and compresses it at the same time. Yes, I need to find new caliper holder first... then my job will be done properlyGirlRacerS14 wrote:Even though you have them in for now, go buy the tool. It's a couple of dollars at the parts store. You need it to put the rear caliper pistons back in on an S14. I would take out and redo when you have the time to make sure they are done correctly. And if I remember correctly you use C clamps on S13's, could be wrong on that. It's been years since I had a 13.
~GR
New guy, welcome to Nico. That's a threadjack. don't do that. start a new thread about your problem. please observe the no-smoking sign until well into the terminal, thank you.bayareastunna wrote:ok well for starters my car wont turn over and start so i compression started it...and it ran fine but im having a problem with my temp gauge it runs hot in about 20 minutes im thinking it may be the water pump...i just replaced the fuel injectors...i also put in new spark plugs bosch to be exact and i was reading a couple of post on here saying that they were really crappy spark plugs for a 240 sx im wondering if that could be the reason why it wont turn over?
