i need two new tires, what do you guys think about this?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Jons_G35_sdn
Car: 2003 G35 sedan-no doggy door,91 240sx sold,04 subaru wrx stage 2
ok right now i have 225/50/r17 on the stock 03 sport wheels(nexen 3000's great tire BTY), ill be needing new tires at the back soon but want to go a tad bit wider. Can i put 235/50 and be ok, will they bulge out to much. There isnt much difference between the two just want to be sure. TIA
http://www.miata.net/garage/tirecalc.html
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You can run those, but I wouldn't go any wider.
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
As long as you are not AWD you will be ok replacing just 2, or stagering the tires.
Jons_G35_sdn
ok i really need tires now and pretty much decicded on going 235s the only thing is they will be about 3/16s taller, do you guys think it will be noticeable?
here is the difference
225/50/r17sidewall: 4.4inradius: 12.9indiameter: 25.9incircumference: 81.2in
235/50/r17sidewall: 4.6inradius: 13.1indiameter: 26.3incircumference: 82.5in
marlin29311
Car: 2008 Infiniti G35x
Might throw off the TCS...not sure though.
Jons_G35_sdn
marlin29311 wrote:Might throw off the TCS...not sure though.
the traction control? The 235/50/r17's are the exact same size as the stock 215/55/r17's, the 225/50/r17's are actually a tad bit smaller. I need rear tires bad though cause there starting to hum .
marlin29311
It's not that the full set is smaller - it's that 2 tires have a different pattern than 2 tires - which is what sets off the TCS. Your rear tires will rotate faster than your front tires...I just don't know how much of a difference the system will allow for.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
