Paul Wall wrote:All i need is someone to provide me the TPS voltage of: (1) When the car is off but the ignition is on (This is when the car has not been started yet). (2) When the car is started up (Meaning the first cold start up) (3) When the car is fully warmed. (4) And when the car has been driven for a while (Please give me the numbers when the engine is still running.
I took both Q's out for spin this morning and have some voltage numbers for you from Nissan Data Scan.
(1) and (2) Cold readings were the same whether the ignition was on (for consult connect) or engine had just started.90Q - 0.66v94Q - 0.64v
(3) and (4) Warm readings (engine coolant at 179*F) were also the same whether the Q's had been sitting at idle or after a spin round town.90Q - 0.50v94Q - 0.48v
