I need to upgrade the ignition but how?
Giallo spyder met
Car: Nissan 200sx -92 Euromodel
I run Haltech E8 and need better ignítion.Now i run oem coils.
themadscientist
do what I am going to do.LS1 coils
Giallo spyder met
Were to buy them and how to install them?
themadscientist
summit or jegs is where I am getting mine. They have built in ignitors too.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Those things look sick.
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
supposedly LS1 coils are good for 1000hp each. Whether thats true or not, thats just what the LS1 guys on the LS1 forum say.
jt15833
Car: 95' 240SX
how "plug and play" is this mod?anything necessary other than buy + drop in
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
jt15833 wrote:how "plug and play" is this mod?anything necessary other than buy + drop in
+ 10 can we get the rest of that story?
The_Chosen_One
You guys do realize he's running Haltech right, so is TMS.
You need a standalone system that lets you pick LS1 coils.
Its not like you can just convert these to run on the CA ignition. Also last time I checked I believe LS1 coils fire Ground to Positive or Positive to Ground, I know its backwards to what most OEM setups fire.
Buddyworm
For a more plug and play dealy find some FET's or some kind of aftermarket ignition for RB series engines on yahoo japan. I believe it's just a matter of soldering in the different plugs to your existing coilpack harness.
Modified by Buddyworm at 1:07 AM 5/24/2008
Giallo spyder met
meminto
Car: S13 Silvia CA18DECT
If you want to upgrade, then you can wire in Bosch coilpacks, Giallo has posted the bosh part numbers.
I use HEC 715's on mine with top gun leads, I also use an aftermarket ignitor (Microtech x4). However you can wire the bosch coils in to the factory harness, effectively making it semi plug n play.
The beauty of it is they are not sitting directly on top of the motor, so they don't get the heat issues that 17+ years of operation give you.
bentvalves
Car: 89 Silvia K's
Giallo, any updates on your project?
Greg
Giallo spyder met
Not much but on Friday i´m going to the tuneshop for somedyno.More to come after that.
Giallo spyder met
Now its dyno on 1.9bar on standard fuel.I had 445Whp.I had to switch the coils over 1.7bar to Bosch Motorsport with wastefire.
More to come.....
bentvalves
Car: 89 Silvia K's
excellent, glad to hear that.
once its all buttoned up, a video of it hammering limiter in 2nd gear is in order I believe...what do you think?
Giallo spyder met
ks13 wrote:excellent, glad to hear that.
Actually it makes the wheels spin in third gear 130-170km/h just on boost.
r34 gtr
Nice man, that sounds sick. I'll bet its just hilariously fast.
Giallo spyder met
bentvalves
Car: 89 Silvia K's
yessir!
themadscientist
This guy is twice wronged.
http://www.maxxtuning.se/index...-0023
Soundly outpowered even with his 800cc displacement advantage and they called his R32 an R33.
