The Mic »
https://forums.nicoclub.com/the-mic-u3737.html
Sun Jan 30, 2005 10:10 am
If you're of average mechanical ability and the job doesn't have snags, no. If you're going to tackle it, do exactly what you're doing for starters: research. Get your specs that are needed as well as an r&r procedure, and you're off. Depending on where you live, or more precisely, where the car has lived, you may need Torches.
The "manifold to head" bolts can be challenging, but shouldn't stop you from trying. The bigger question you face is "is it just a head gasket?" It is possible that the gasket may have been blown from warpage in the head, in which case the head should go to a machine shop for cleaning, pressure testing, maybe magna-fluxing for cracks, and machining if it is okay. You could put it together and still have a problem. So send it to a machine shop unless you are just going to get a reman head. I don't know what size engine you have, so I can't get too specific, I would guess a 2.2 or 2.5. Fair chance of a cracked head if so. Tightening specs and sequence are important for the head bolts. Plan on new ones, toss the old ones. Get a new thermostat while you're in it. Overheating can damage a thermostat.
Getting back to the original question, yes, you can do this, be patient. IF a bolt snaps a machine shop can help you. Continue to research this before you start. Good luck.
EDIT: Because you may have warped the head, you might need to get the head machined or get a new one. So get the head checked before doing anything. This can be the price of a different engine if you get it done at a shop. You could still drive your car like this but dont expect to get much more life out of the engine. If you wanted to do a swap now is the time to sit down and make a choice.
