I need to no where these wire to a BLITZ turbo timer go?
myr32skyline
Car: 1992 240sx coupe se converted to a r32 skyline
BLITZ turbo timer have the harness and everything
myr32skyline
also these wires
burnout 180
Car: 1990 s13 180sx ca18det
should he search?
beans33
Car: 1993 ca18det 240sx
I cut the clip off the end of mine and then spliced it into the ignition wires right under the steering wheel. The orange is illumination i wouldnt worry about that there should be 2 grounds and a purple wire that hooks up to the E- brake.
tyrannix
Car: go big or go home
he already has a harness adapter, no need to snip/solder the main harness
take off your steering column coverlook underneath, there will be a connector down there, unplug it and stick that adapter in between them
the other wires will probably be for your sidebrake, tach, maybe O2 and whatever else blitz packed onto that turbo timer, youll need to find a manual to know which wire goes where
hint: google
myr32skyline
thanks man i need all the help i can get im new at this **** sorry to sound so damn dumb but i have no idea you know
