Logan76 »
https://forums.nicoclub.com/logan76-u38992.html
Fri Feb 02, 2007 5:37 pm
Will bolt in using stock mounts and R32 crossmember.you can also use aftermarket ones from companies such as McKinney and TopHatWill use stock 5 speed driveshaftCustom downpipe may be needed for both S13 and S14Electric fans are requiredCustom throttle cable bracket may be requiredTach adapter or gauge cluster swap required for accurate tach signal
Ask the importer you buy your motorset off of for an R32 x-member, probably pick it up cheap man.
I found that in 20 seconds!!! PLEASE SEARCH!!
