i need to get rid of bose
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
i need help here ive got to get ride of my bose headunit in my 00 i3oive already have an aftermarket headunit, monitor, and amp an subwoofer. i need to find a double din kit and have looked everywhere.
snwbrdr435
also would my stock bose speakers work with my new headunit?
audtatious
Bose speakers won't work. You will need to replace them.
Look for a Metra kit to use a Din radio. I have also seen people use the factory trim plate from a '02-03 Maxima that had factory navigation (tho Nissan kinda overcharges for it)
snwbrdr435
theres no way to integrate them at all?
blazncypher
Car: 01 I30
the bose speakers will work you will just have to hard wire them, if you dont have a good amount of experience with car audio i would suggest having it done by a professional so you dont fry anything.
audtatious
Bose mids are 1ohm speakers. This is too low for a headunit and, while possibly working for a bit, will result in the HU outputs failing.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
If your headunit has RCA outputs, you can cut up some RCA cables and wire those to the speakers. Did that on my Z until I could get some speakers and it works great. You should be able to do that too if they kept the overall design the same (pre-amp headunit, individually amped speakers).
audtatious
The speakers in the 00+ Maxima are not amplified. The amp is under the back deck.
snwbrdr435
audtatious wrote:The speakers in the 00+ Maxima are not amplified. The amp is under the back deck.
i thought i read somewhere that the bose speakers in the infiniti were amplified?
audtatious
Older Maximas had the amps directly on the speaker themselves. The 5th-gen model actually has a dedicated 5-channel amp that is under the back deck.
Trust me, I've done a stereo install in my car and another members '00 Maxima
blazncypher
Car: 01 I30
if they truly are running at 1ohm then it would make more sense to get new speakers or rerun the speaker wire to a new 4 channel amp that can handle one ohm. i would check to make sure they really are 1 ohm though. 1 ohm is usually used when you have a really good amp with a really good system, and the bose are mediocre in my opinion.
audtatious
Bose has consistently used 1ohm speakers throughout Maxima history. The only speakers that are not specifically 1ohm are the tweeters which are 4ohm. I have put a meter on my mids and they showed 1.4-1.6 ohm.
mtcookson
1992 Iinfiniti Q45
and much much more
Do they run separate wires for the speakers straight to the amp? If so, you might still be able to do the RCA cable thing. Freakin' Blose... err, Bose.
audtatious
Not really. 1 pair run up to the front seperates. Guess you could do the RCA "thing" at the radio itself and tap into the factory harness going to the factory amp. Might inject noise into the system tho.
5th-gen radio wiring diagrams are listed on http://www.maximaclub.org
snwbrdr435
thank you nissan for puttin bose in your cars it makes people miserable
