i need to drain all my fluid
180fastback
Car: 240 sx
what fluids is gonna be good for my car. oil, coolant, brake etc.. what else do yah think i should do to it.. i just bought the car like this sunday 89 s13 coupe it has SOHC motor with 200000 miles on it.. what do yah think i should do to keep it runin.. fluids parts and all that i should replace.. thanks in advance.. ohh yea its a 5 speed..
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Do a basic tune-up.
Change oil and filterChange transmission and rear diff fluidspark plugsplug wiresdistributor cap/rotorflush radiatorcheck/replace if necessary thermostat, radiator cap, water pumpo2 sensorsfuel filter
I use Prestone CoolantValvoline Syntec Oil (5W-30)Penzoil Syncomesh transmission Fluid (75W-90)Valvoline (80W-90) gear oil for the rear diff
That should start you off. For everything else there's a search button on the top right of this forum.
Welcome to Nico!!
180fastback
Car: 240 sx
how do i drain the transmission fluid and the diff fluid,,
ddgsxr504
Not to be mean but is this the first car you have ever owned??
The drain plug is on the bottom of the transmission in the middle and the rear diff drain plug is on the back at the bottom. The fill hole for the transmission is on the driver's side of the transmission (fill until fluid comes out of the side then cap it off. Same with the diff.
180fastback
Car: 240 sx
how would i know if i have enough fluid in the transmission and the diff.. if it start to over flow thats when i need to stop and cover it up..?
dickie
Car: Killer Turtle
theres an fsm, if you can read it, available to you. searching will also yield a lot of this info.
