Post by onelove. » https://forums.nicoclub.com/onelove-u118238.html Wed Feb 18, 2009 7:59 pm
Post by G_whizz » https://forums.nicoclub.com/g-whizz-u38189.html Thu Feb 19, 2009 5:08 am
Post by av8or » https://forums.nicoclub.com/av8or-u92327.html Thu Feb 19, 2009 7:28 am
i have replaced mine to LEDs... there are 2 ways of doing this.. taking out your bumper to remove your headlights which is a PITA.. or just going thru your wheel well... i prefer the latter... anyway you do not need to remove your wheels, just turn it to one side, remove the 3 clips and one screw, and push the plastic inside... if you look at g_whizzs' link, you will actually be working with the piece which is not circled, next to the red one..onelove. wrote:okay so i have an 05 coupe and my little light strip went out on one side. im planning on changing them both out to LEDs. does anybody have a write up or know of a write up that i can use to change them?? thanx alot guys
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
