i need this! wtb with picture!!
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
i need this little guy, its a fitting of some sort coming out of the back of the intake manifold, its threaded so i assume you can just unscrew it, but i havent tried. anyways the kid i bought this motor from said he didnt break anything when he pulled it but whatever. does anyone have one of these i could buy off them? give me a price shipped to 98362. thanks!
Buddyworm
I'm sure you'll be able to find a piece to replace that. Take it out and start hitting up your local Napa/other part stores. It might not be exactly the same but something is bound to work.
Tyler
i know i could do that, and i still might. but i see so many people parting out ca's and i would rather have the correct part
mazikowski
Car: 2013 Subaru BRZ Ltd 6MT, 1984 CA20E 200sx, 1981 L28E 280ZX
That's the vac nipple for your brake booster IIRC. Anything that is the same size and thread should work (make sure the nipple part fits the booster hose)
hydraulx
Car: 1991 S13 CA18DET
Almost all nissans have the same threaded fitting. I got mine of a sr20 but the one off a ca18de works. ill check if the ka one fits tomorrow
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
Remove and LOWES/HomeDepot FTW~!! ^_^....
float_6969
I'd hit up a hardware store as well. It will be MUCH cheaper.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
the KA one does fit, its what i had to use. yea Home Depot would probably be your best bet if you can't find one from a KA,SR, or other CA. just make sure the piece you buy is long enough. I made that mistake before
bradt
Car: 1989 240SX CA18DET
You will need to find it in a pipe fitting section. Be cautious though, most auto stores will only have NPT fittings. The thread you need is British Standard (BPSS I believe). NPT may work, but usually it has too large of an outer diameter. Find a plumbing or industrial supply store with metric fittings and you will be fine.
articzap
Car: 2014 F150 FX4
bradt wrote:You will need to find it in a pipe fitting section. Be cautious though, most auto stores will only have NPT fittings. The thread you need is British Standard (BPSS I believe). NPT may work, but usually it has too large of an outer diameter. Find a plumbing or industrial supply store with metric fittings and you will be fine.
This guy is totally correct. Its an expensive little guy. What I did was goto a hydraulic store. The sold me a BPSS fitting to convert to NPT. Then an NPT fitting with a hose barb. Mine now just comes straight off the back of the manifold. The 90* wasn't worth trying to keep.
rico05
Car: 1992 RMS13 w/ CA18DET
It is BSPT (British Standard Pipe Thread).
Why not just pull it and weld it back?
